Sun, Feb 9, 12:08 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Precise positioning c5pro
ddaydreams ( ) posted Mon, 22 May 2006 at 9:14 PM · edited Wed, 05 February 2025 at 6:29 PM
Rather than dragging an object around on screen with mouse is the a way to do it by numerical input?
Frank Hawkins/Owner/DigitalDaydreams
Frank_Hawkins_Design
Frank Lee Hawkins Eastern Sierra Gallery Store
My U.S.A eBay Graphics Software Store~~ My International eBay Graphics Software Store
Patrick_210 ( ) posted Mon, 22 May 2006 at 10:44 PM
Sure, when your object is selected, there are numerical coordinates in the right hand tray under the motion tab.
ddaydreams ( ) posted Mon, 22 May 2006 at 11:04 PM
Thanks
I thought that was it.
I tried that yesturday and could not get an oject to move, but tried again now and works fine. Hmmm.
Anoughter question : can the mouse be set to drag in smaller increments? I was getting too much movement useing mouse, that why I wanted numerical. Any help?
ren_mem ( ) posted Mon, 22 May 2006 at 11:51 PM
There aren't any custom settings for the mouse or tablet in c5 or hex of which I am aware.
No need to think outside the box....
    Just make it invisible.
ddaydreams ( ) posted Tue, 23 May 2006 at 12:17 AM
sfdex ( ) posted Tue, 23 May 2006 at 11:09 AM
If you're using multiple views (isometric as well as orthographic), I find that zooming in considerably in the top, left or front view and dragging there, as opposed to using the omnidirectional move tool in the perspective view allows for much finer movement.  Zooming in on the view in the perspective window can get a little confusing when you go to dolly the camera around, so I just keep it wide enough to see the entire production frame and zoom in the isometric views.
 - Dex
ddaydreams ( ) posted Tue, 23 May 2006 at 11:25 AM
ramble1035 ( ) posted Tue, 23 May 2006 at 6:48 PM
You also have the ability to "nudge" an object using the arrow keys, which may give you more control than the mouse but less trial-and-error than using the numeric fields. Check somewhere around pg 148 in the manual (or just use the text search feature in the Adobe Reader to find nudge): "Press and hold the Command/Ctrl key, and then press the arrow keys to move the object in the active plane." You can also use the shift key to get smaller increments.
anxcon ( ) posted Tue, 23 May 2006 at 11:06 PM
windows also has a setting to make the mouse more/less sensitive
so the setting is in windows, not carrara, but it does the trick
