Fri, Jan 31, 11:09 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Alpha Channel and Poser 6
Fredoray ( ) posted Mon, 22 May 2006 at 5:13 PM · edited Fri, 31 January 2025 at 9:25 AM
Poser 6 is so full of mysteries... I really wish it was a bit more like the old poser... in Poser 4 if you rendered out a tiff using the "against black" option it created an alpha matte and you could use to lay the pic over any number of other backgrounds later... now in Poser 6 a render using the "against black" gets you just that... black. What can you do to create an alpha matte in the rendered tiffs??? really desperate to know. Thanks in advance. FRED
SamTherapy ( ) posted Mon, 22 May 2006 at 5:26 PM
I don't often save as TIF, I save as PNG, which gives you the blank alpha channel anyhow.
Fredoray ( ) posted Mon, 22 May 2006 at 5:45 PM
Cool -- I'll try it.
Latexluv ( ) posted Mon, 22 May 2006 at 6:45 PM
I render out as tiff. I started that back with Poser4. I rarely use 'render as black', I simply change the background color in the studio to black and render. I've had no problems with bringing these tiffs from P6 into Paintshop and using the alpha chanel to delete the black background. Try changing the color of your studio's background to black rather than using the 'render as black' option and you might loose your problem.
I did not know that ping format has an alpha channel. The only other format that I found with alpha channel is Poser besides tiff was targa.
Weapons of choice:
Fredoray ( ) posted Mon, 22 May 2006 at 7:11 PM
Rendering out as a png did the trick... Many thanks!!!
dlfurman ( ) posted Tue, 23 May 2006 at 1:28 PM
If you are using Photoshop you can also save as .PSD and use the Load Selection>alpha 1, check Invert option there as well.
