check your local library, and see if they have reference material on photographic modelling. I have a similar book that basically outlines in thumbnail format, basic modelling poses to utillise when doing a photoshoot. I works great, as a reference guide when posing in poser....
"If toast
always lands butter-side down, and cats always land on their feet,
what
happens if you strap toast on the back of a cat and drop
it?"
Steven Wright
Attached Link: http://www.e-frontier.com/article/archive/319/
Check out the tutorial at e-frontier by Schlabber (Stephan Schoneberg.) it's bloody brilliant."you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
The real secret, assuming you're able-bodied, is to adopt the pose yourself. Concentrate really hard on how your muscles are pulling or pushing, and how you need to rotate your joints. Work out where your centre of gravity is. And once you've used that info to get your Poser figure positioned, spend as long as it takes to get the hands posed realistically. Oh, and save partial poses as you go along .. you'll soon build up a useful library of arm, leg and hand poses.
That's a great tip, moochie. Do you know of a quick and easy way to save partial poses? I always end up saving the pose then opening with MPE and deleting the extraneous bits.
"you are terrifying
Shire
Yes .. click Add to Library, then Select Sub-Set in the window that pops open. Take the X out of Universe, then X every part you want to save the pose for. Probably a good idea to put 'pp' or something in the pose name, so you know it's a partial pose.
I should add that I've found it best to save poses with IK turned OFF. With it on you risk getting odd results when the partial pose is applied, and it also doubles the size of the pose file, unnecessarily.
Blimey... 3+ years using Poser and I never investigated the subset option. LOL! Thanks moochie :-)
"you are terrifying
Shire
there is so much, so much, to Poser.
It's a new ting every day
Thanks for the pose saving info, moochie :)
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
You can probably make any pose you try by starting with a premade one that is similar, then just tweak the parts you need to change.
say." - Ghandi
Does anyone know where I can get a TUT or proggie on making realistic poses in Poser 6? Thanks in advance.
Adrian
