Fri, Nov 29, 7:18 PM CST
Subject: Natural Poses
Circumvent ( ) posted Thu, 25 May 2006 at 8:48 PM · edited Fri, 29 November 2024 at 7:08 PM
Does anyone know where I can get a TUT or proggie on making realistic poses in Poser 6?  Thanks in advance.
Adrian
LostinSpaceman ( ) posted Thu, 25 May 2006 at 9:39 PM
First thing you should always do if you're posing by hand is turn on Limit's for the figures you pose. This will keep them from bending in ways humans shouldn't bend if you drag any body part too hard in the wrong direction.
Gora ( ) posted Fri, 26 May 2006 at 2:43 AM
check your local library, and see if they have reference material on photographic modelling. I have a similar book that basically outlines in thumbnail format, basic modelling poses to utillise when doing a photoshoot. I works great, as a reference guide when posing in poser....
"If toast
always lands butter-side down, and cats always land on their feet, what
happens if you strap toast on the back of a cat and drop it?"
Steven Wright
KarenJ ( ) posted Fri, 26 May 2006 at 3:09 AM
Attached Link: http://www.e-frontier.com/article/archive/319/
Check out the tutorial at e-frontier by Schlabber (Stephan Schoneberg.) it's bloody brilliant.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
Circumvent ( ) posted Fri, 26 May 2006 at 4:18 PM
Thanks everyone for responding.  I will try it out and see what happens.  Thanks again.
Adrian
Gongyla ( ) posted Fri, 26 May 2006 at 4:46 PM
Karen is right. That tutorial by Stefan is really outstanding.
moochie ( ) posted Fri, 26 May 2006 at 5:15 PM
The real secret, assuming you're able-bodied, is to adopt the pose yourself. Concentrate really hard on how your muscles are pulling or pushing, and how you need to rotate your joints. Work out where your centre of gravity is. And once you've used that info to get your Poser figure positioned, spend as long as it takes to get the hands posed realistically. Oh, and save partial poses as you go along .. you'll soon build up a useful library of arm, leg and hand poses.
vince3 ( ) posted Fri, 26 May 2006 at 6:08 PM
another good habit is to NOT drag body parts to achieve pose!!! but to instead use the parameter dials to achieve pose as they are much more acurate and precise!!!you will never get a decent realistic or natural pose by draging body parts as draging moves parts that shouldn't be moved!!!
KarenJ ( ) posted Sat, 27 May 2006 at 7:03 AM
That's a great tip, moochie. Do you know of a quick and easy way to save partial poses? I always end up saving the pose then opening with MPE and deleting the extraneous bits.
"you are terrifying
moochie ( ) posted Sat, 27 May 2006 at 7:19 AM · edited Sat, 27 May 2006 at 7:22 AM
Yes .. click Add to Library, then Select Sub-Set in the window that pops open. Take the X out of Universe, then X every part you want to save the pose for. Probably a good idea to put 'pp' or something in the pose name, so you know it's a partial pose.
I should add that I've found it best to save poses with IK turned OFF. With it on you risk getting odd results when the partial pose is applied, and it also doubles the size of the pose file, unnecessarily.
KarenJ ( ) posted Sat, 27 May 2006 at 8:42 AM
Blimey... 3+ years using Poser and I never investigated the subset option. LOL! Thanks moochie :-)
"you are terrifying
ScotHarvest ( ) posted Sat, 27 May 2006 at 9:05 AM
Wow.. Moochie that was a REALY usefull piece of info, I'll have to go try it RIGHT now THANKS!
"Dance like nobody's watching; love like you've never been hurt. Sing like nobody's listening; live like it's heaven on earth."
  --  Mark Twain --
Dave-So ( ) posted Sat, 27 May 2006 at 1:34 PM
there is so much, so much, to Poser.
It's a new ting every day
Thanks for the pose saving info, moochie :)
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
Acadia ( ) posted Sat, 27 May 2006 at 6:05 PM
You can probably make any pose you try by starting with a premade one that is similar, then just tweak the parts you need to change.
