Sat, Nov 23, 7:38 PM CST
Subject: CR2 Problems
ronwindham ( ) posted Sat, 27 May 2006 at 8:40 AM · edited Sat, 23 November 2024 at 5:40 PM
Have Poser 6 and when I saved some characters (cr2's) they referenced a drive letter instead of a runtime/lib whatever. Nw have a different puter and that drive is not poser now. Is there a setting someplace in Poser to make them reference a file location instead of a drive location??
Have checked the book and can find nothing about this there. Oh yes poser is on an external drive all this time same drive. But got new puter and windows changed dives letters for me ( all sorts of card rader slots)
Thanks
nickedshield ( ) posted Sat, 27 May 2006 at 9:55 AM
What you need to change are the two figureResFile lines. You probably have figureResFile xPoser6folderfile change that to figureResFile :runtime:geometries:folder:file.OBJ With P6, check to see if it created a new obj file in the character folder you saved your cr2, it has a nasty habit of doing this. If so, change the geometries to where your obj actually is located. Hope I didn't confuse you too much.
modus0 ( ) posted Sat, 27 May 2006 at 10:31 AM
Just to clarify, nickedshield is talking about manually editing the cr2 with a text editor.
Also, if you know where the needed files are, you can try opening the cr2 up in Poser and when it says it can't find the file you can tell it where the file is, and once the character is loaded, re-save back to the library.
Either way will work.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
svdl ( ) posted Sat, 27 May 2006 at 10:34 AM
Attached Link: http://www.globetown.net/%7Ekim99/tool/index_e.html
Fixing up a CR2 is easier using a CR2 editing tool. I use CR2Builder by kim99, free and easy to use. See attached link.
My gallery   My freestuff
TrekkieGrrrl ( ) posted Sat, 27 May 2006 at 11:07 AM
Why not use Correct Reference for it? The Pro version can do this IIRC. And it's a darn nice tool anyhow :D
ronwindham ( ) posted Sat, 27 May 2006 at 10:24 PM
Thanks all.....yup did the edit of cr2 first , got tired of waiting for note pad to open them......and just got cr pro have it running now...I figure all day there beings it's the first time it ran.....
Got it figured out not thanks again.
ron
