Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Dude, those links are full of popups!
Try posting them somewhere else, then click the Insert/Edit Image button above in the toolbar and paste in the URL of the image. If you can't see the image, then it's not available from the URL.
The url you've given are actually dynamic URL's (see the ? in the middle). The Insert/Edit Image feature only works with a static URL link.
-Chipp
One thing about the grain, you need to change some settings in the atmosphere editor. in the light tab, push the ambient light slider towards sunlight 60% at least, and right under it, push the ambient light from... towards sky, 60% as well. Should get rid of the unwanted grain. Also use more AA, the render you show has soft shadows that beg for higher anti aliasing settings, but I guess it's only a preview render.
Now about your textures, you say they are procedural, and not bitmaps, right? Try different space coordinates for them, try object standard, parametric, try reducing the mat size, or doubling it. the worn red wall to me looks too bumpy. Also, you could mix it with a dull white & grey material that would simulate dirt and age, and drive the mixing proportions by a fractal function.
If you have the texture for the outside in photo format, then just use it. Make it tileable (search GOOGLE for Photoshop and Tileable textures), and apply it Object Parametric and adjust the scale. BTW, the bump is too great on your procedural texture.
The lighting outdoors looks pretty good, but you've the plant in front is too big and there's too much saturation overall in the colors. Not sure what the wood grain is supposed to be.
Concrete walk is too bright and colorful. Think of concrete as gray with only a little blue reflected light affecting it. I like the viewpoint.
The interior shot needs you to setup the anti-aliasing better to get rid of the noise in the shadows. Search for Peggy Walters great PDF file on how to setup rendering settings. Or check out Eric Holbrook's fine page on render settings.
HTH, Chipp
I need C&C!!!!
these are two renders for a small horizontal condo I'm working in.
In the interior one, I don't like the borders oh the sun's highlights, i'd like them to be sharper, without that grainy look. Inly I don't know how to do that. Also, the material in the left wall is some kind of red tezontle stone squares very used in mexican colonial architecture (like the ones in the attached photo).
I spent a night making that procedural material but I did not like very much the results. If you wish send me your e-mail and I'll send you the procedurals so you can see how did I make them.
The ideal material for the seats could be some black leather, any idea on how to make it?
About the exterior one, say anithing you think I could do to make it better...
I can't post the images directly in the thread ... suggestions please?
you're saying CG sunlight is actually based on a real thing????
