Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 4:45 pm)
It's possible I guess. But wouldn't that be a violation of copyright if that were the case?
say." - Ghandi
Quote - It's possible I guess. But wouldn't that be a violation of copyright if that were the case?
Not if the photo above was the one used. It's a 3d.sk pic. Their terms allow you to use the pics for modelling and texturing.
they certainly got her arms wrong in several areas, but the typical way daz and e-frontier create 3D figures is from scans of actual humans. if a modeller can create an accurate 3D figure without using actual human scans as the starting point, said modeller is either a genius, or is likely copying a previous model's geometry.
Quote - they certainly got her arms wrong in several areas, but the typical way daz and e-frontier create 3D figures is from scans of actual humans. if a modeller can create an accurate 3D figure without using actual human scans as the starting point, said modeller is either a genius, or is likely copying a previous model's geometry.
Well, it's possible to do it if you use a set of artist's sketches based on a human canon. I could do the drawings, no problem. Modelling, however, is not something I'm much good at.
exactly, sam. there are so many small details that can be missed when not using a 3d scan, whether it be the old-style laser thing, or one of those robot arms that moves along the contours, touching the body everywhere. the fingers are particularly tedious zones, from a practical viewpoint, hence we have seen at least one case where the "modeller" copied daz hands to save time. I just think it's unfortunate in this case that Aneta has such graceful, feminine fore-arms and hands, whilst miki's proportions in that area are more similar to "pop-eye" IMVHO.
Looks possible. Timberwolf, I've seen the Anita pics and remember she had a distintive lack of curl(Xrot) in her lower back just over her butt. A profile would show that. Also why Miki is more "tucked" from Bottom to leg than V3. And some pointy shouldeblades. Big noses, too...:^l Just seems CL would have scanned someone rather than use "eyeball" photos without any graphs or limb supports. According to a previous thread, Miki2 will be welded and would make this morph of yours a lot easier. I had to get Miki welded in Lightwave and hack it into the cr2 before I could do a decent bodymorph. Miki 1 is a collossal pita. She was never "finished". Split verts in her feet, holes in her neck, 2 UV errors and unfinished joint zone editing....All these will make you suffer when you try to re-import. Just thought I'd warn you.
Quote - ...there are so many small details that can be missed when not using a 3d scan, whether it be the old-style laser thing, or one of those robot arms that moves along the contours, touching the body everywhere...
Is there a website that shows how exactly those things work? I think it would be cool just to read about it or even see one in action. Also I wonder what the prices are to get an actual scan of somebody or something.
-James
Attached Link: http://graphics.stanford.edu/papers/digmich_falletti/
. Also I wonder what the prices are to get an actual scan of somebody or something" I know the scanners are right up there. $180K + I was involved with 2 10' object scans (low res) that were rapid prototyped into foam with a die grinder running from the coordinates.. This cost $24K for both. Hate to guess what one Hi-res would cost. Lots of variables including the rep of the Co. I think the best way to do it would be to do the classic silicone body mold and correct it back in the positive plaster casting. This could stand indefinately while a hi res scan could be made. Breathing, tired arms, figiting have bad effects. I'm sure everyone will be using this tech in the near future. Especially when demand goes up.I have no idea as to what was the source, but if you overlay 10 women of the same build you will get the same results. This is something akin to claiming someone copied a figure based on the shape of the Human Body. Since that shape is pretty universal, making such statements is not very convincing evidence.
ratscloset
aka John
Quote - I have no idea as to what was the source, but if you overlay 10 women of the same build you will get the same results. This is something akin to claiming someone copied a figure based on the shape of the Human Body. Since that shape is pretty universal, making such statements is not very convincing evidence.
Yeah you're right. Every human body with the same build is exactly the same in every detail.
