Fri, Dec 27, 4:59 AM CST
Subject: Space scenes - how do you get rid of the ground?
Grayhem ( ) posted Fri, 02 June 2006 at 11:25 AM · edited Thu, 26 December 2024 at 1:57 PM
If you want only space, stars and planets, how do you get rid of the ground?  Do you just point the camera up in the sky or can you actually get rid of every trace of ground?
Sorry if this is such a simple thing - It isn't obvious to me!
We are trying to do a fly-by of Earth
bobbystahr ( ) posted Fri, 02 June 2006 at 11:47 AM · edited Fri, 02 June 2006 at 11:50 AM
Yes..delete the ground from the right hand browser and in Atmosphere, I believe there is one that is set up for outer space, check all the catagories in the materials browser, I can't as I was using a demo that ran out or I could have told you exactly which one it's in...enjoy outer space...LOL
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
garyandcatherine ( ) posted Fri, 02 June 2006 at 1:41 PM
Delete the ground plane and then go into the atmosphere set up and MAKE SURE that fog, haze and all the other options are set to "0".
G&C
jc ( ) posted Fri, 02 June 2006 at 3:56 PM
Besides deleting the ground (an infinite plane), there are 2 atmopheres for space and no atmosphere planet scenes. One is just black and one has stars on black (Vue 5 Infinite).
Phantast ( ) posted Sat, 03 June 2006 at 2:17 AM
This can be a problem when you actually want a picture full of sky, with atmosphere but no ground. Deleting the ground plane doesn't give you a 360 degree sphere full of sky.
One trick that I have used successfully is to give the ground plane a mirror texture.
