It cannot be done - not in the fashion you (and I and everyone) expected anyway... You can either go through the laborous task of exporting the model's individual movements as obj and importing and rendering and importing and positioning next one and render, etc... ludicrous nuisance! Or you can, depending on what's happening in the anim, render your Bryce 'set' or setting and use it as a background image in Poser to animate against. If your background doesn't require movement this is not a bad method. It has worked nicely for me twice - especially in an anim Im going to post shortly. So knowing that method, with proper planning you can get around this until Bryce 5 when I've got to assume they're gonna make just importing the animation data with the model happen. Dave www.citizendave.com
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=253913
a clickable link of the above. Bryce 5 is currently in Beta testing. No information from Corel is available regarding a release date, but stuff in beta testing usually comes out before year's end. If we're lucky it will be out this summer, who knows.Flickerstreak: Has there been any info (or rumors) indicating that Bryce 5 will be able to import Poser 4.1 animations? Also, what did you do to make your link (as above) active (clickable)? I typed mine in, but although it is a good link, you would have to cut and paste it. Do you have to type in the HTML code? Seems like I have posted active links before without having to code them. . .
Attached Link: http://server3006.freeyellow.com/3908/stats/cleaned.mov
Decent results can be had with a bryce animation as background footage MocapThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I was wondering if there is a way to bring an animation from Poser 4 into Bryce 4.1? If you can help i would appriciate it greatly. Thanx!
