Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
I would delete all the spokes except for one and EDIT/DUPLICATE or (cmd+D on a Mac) and that will create multiple instances but only one master object for all of them. So when you edit the master, it will update all of them. Chucker P.S. Keep all of the current spokes in place, duplicate one of them, move the duplicate spoke into position where it should be on the wheel. Then when you tell it to duplicate again, it should move the next ones into place automatically all the way around the wheel as you duplicate. If this sounds confusing, then just keep the original ones there for reference, make your duplicates and put them in place where the current spokes are, then delete the old spokes when you are done.
I have imported a wagon wheel vertex object with many spokes. Each spoke is individually named but they are all identical. They do not have a common master so they each show up as a unique vertex object with its on master. Since I would like to change the diameter of the spokes and their UV mapping so I can texture them, it would be great if there was a way to link all of them to one master. In this way you could make the changes once instead of having to repeat the changes for each spoke. Anyone have any ideas on how to do this?
