Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 12:41 am)
Thoretically, you should be able to inject any morph for V3 into her. You will get some significant differences in how the morphs actually work (scale and shape are different, which will produce results that have usually very little corellation to the original).
Best bet -- Morph mover, here in freestuff, I think. Load a v3 with all her morphs, save her to the library, and then move them into the Laura figure.
It's worked for me, at least, lol
I injected a V3 head that I'd made for V3 into laura and it worked the same I think. Love esther
I aim to update it about once a month. Oh, and it's free!
well then Laura must be very similar to V3, because I made an injection pose for a V3 character I had made, and injected it into Laura and it looked very similar if not the same. Love esther
Did I mention no morph transfering software used. Love esther PS this was just the head of course
I'm a bit fuzzy here on just how to inject V3 morphs into Laura. Do you just go to the !V3 All Body folder and click on the png for the morphs? I tried that and nothing changed on the Laura figure dials. I did, however, get a head from one of the character downloads to work....it's all just so confuzing at times...
Quote - I'm a bit fuzzy here on just how to inject V3 morphs into Laura. Do you just go to the !V3 All Body folder and click on the png for the morphs? I tried that and nothing changed on the Laura figure dials. I did, however, get a head from one of the character downloads to work....it's all just so confuzing at times...
Laura works in exactly the same way as V3 does (although the results of the individual morphs can vary..)
IMHO, this is not the best way to go about things though. The INJ/REM stuff was created to avoid having all the morphs loaded into a figure, especially if only a few of them would actually be used. V3 (and Laura) have "empty" slots where morph values can be plugged into. The behind it idea is to only load the morphs you want to use and no others, thus saving memory.
Loading everything (via INJ/ALL) bloats the memory use significantly....
Cheers,
Diolma
I've tried injecting some V3 morphs into Laura without success - same with Maddie - because the morph channels don't exist in the figure, even when using Morph Manager. I had more success after using the ATC ("All Those Channels") Python script from the Free Stuff area. For example, I wasn't able to get the International Beauty morphs to work by simply injecting them.
I've also found, sometimes, that the morphs may load, but not display, and I've had to go into the CR2 in a text editor and change the "hidden" setting from "1" to "0."
Hi, well I had a V3 head and body pose that I made useing the commercial pose injector thingy that I had once bought from daz. I injected it into laura without using morph manager or injecting any morphs prior, and her face took on the V3 (my pose) look and channels with dial settings appeared for her head in the parameters. Love esther
You need to load a pose file in both sides of MorphManager before you load the .Cr2's. Then all morphs and channels show and can be transfered. I have both L3 and Madie with the International Beauties inject channels.
I guess that's why there are so many different ways to do the same thing. Some find it easier one way than the other ways.
Any helpful hints on how that works, beryld? I loaded the pose I want (!V3 Jaw Forward), but I don't see anything in the window. The help file says this can be done, but I don't see any obvious way to transfer the pose to the CR2 file.
Thanks for the tip - if I can get it to work, it will be a real boon! ;-D
Right Click and copy all morphs of all the groups, except the body.
Body needs to be copied differently, this will give all your PBM's. Copy all channels except the (trans,scale offsets and rots. You can delet these first and then use copy all to save time.)
That's it. Pretty simple.
Hi, I was wondering how to transfer or inject some of Vicki 3's morphs into the Young Teen Laura, and if it is only some of them can be injected or all of them. Anyone know?
