Sun, Feb 16, 6:06 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Mark- Can This Be Done In Carrara?
Veritas777 ( ) posted Thu, 22 June 2006 at 3:39 PM · edited Thu, 13 February 2025 at 10:46 AM
http://www.renderosity.com/mod/forumpro/media/folder_7/file_343648.jpg
Hi Mark-
This is a render by Mobius in Lightwave- Polygons "turned on" an with an ambient occlusion shader.
Can polygons be "turned on" in Carrara- and/or does this above efx require one of the Digital Carver's Guild plug-ins maybe?
mmoir ( ) posted Thu, 22 June 2006 at 6:17 PM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=583659&member
Veritas777,
  Toxe had done several images like this , check out his gallery .  Here is a link to one of his images. His paper renders looks much like this and I think he used just GI and NPR but not sure.
Mike
MarkBremmer ( ) posted Thu, 22 June 2006 at 6:46 PM
Hi Veritas, You can fuss with settings in Toon III that comes with Carrara (there are "softer" settings). It's just that ToonPro and Wireframe Pro does a better job. The other way with NPR is just to make sure that the Diffuse layer is clipped to the object with lines selected - but that won't give ambient effects. Mark
Veritas777 ( ) posted Thu, 22 June 2006 at 8:38 PM
Mark and mmoir-
Thanks for the posts and the examples! This gives me some further ideas to explore for some images I'm working on. Davide sent me some really nice NPR brushes- but none of them relate at all to the images in his art gallery.
The combination of Toon/NPR with GI and/or ambient occlusion is a really nice effect...
ShawnDriscoll ( ) posted Fri, 23 June 2006 at 1:51 AM
Wireframe Pro is great for that.  Just model in quads so you don't get diagonal lines showing on your walls and cabinet doors.
cckens ( ) posted Fri, 23 June 2006 at 4:54 PM · edited Fri, 23 June 2006 at 4:54 PM
This is a quick and dirty render using the wireframe render on C5.  I inverted the image, then set the layer above the other in Overlay mode.  It's not quality, but it does work... to a degree.
Ken
