Tue, Feb 18, 12:10 PM CST
Subject: PICK room creator for poser - model wont import to vue!
monkeydesign ( ) posted Thu, 22 June 2006 at 10:06 PM · edited Tue, 18 February 2025 at 11:51 AM
hi i have created a full room in poser using the pick room creator props - but when i import the model to pvue the doors and windows are missing and props scattered arround the room!
any ideas why this is going on?
thanks guys..
www.monkeydesign.nl - creative web design, graphic design, and new media solutions.
thefixer ( ) posted Fri, 23 June 2006 at 9:57 AM
Sounds like you were burgled!!!
Sorry couldn't resist!!!
Injustice will be avenged.
Cofiwch Dryweryn.
monkeydesign ( ) posted Fri, 23 June 2006 at 10:09 AM
very usefull thanks for nothing!
nruddock ( ) posted Fri, 23 June 2006 at 1:48 PM
What edition of Vue are you using ?
Are you importing OBJs or PZ3s ?
Do you have "Resize and center imported objects" checked ?
monkeydesign ( ) posted Fri, 23 June 2006 at 4:07 PM
esprit and pz3's!
is this a common problem?
thanks n!
nruddock ( ) posted Fri, 23 June 2006 at 4:54 PM
Quote - is this a common problem?
No idea.
Having had a try at this, unchecking "Group figures as single meshes" seemed to be what was needed.
Make sure you have "Use external binary morph targets" unchecked when saving from Poser.
Remember when asking questions, give plenty of information.
You can tell what's likely to be relevant from other threads, but which version, and what options your using for a particular operation are generally going to be important.
monkeydesign ( ) posted Fri, 23 June 2006 at 6:27 PM
ok - thanks for the tips ill have another go i have been un-checking external binery bizness so will try the group as single meshes bit and see if that works!
thanks again your help is really appreciated!
meselfr ( ) posted Sat, 24 June 2006 at 8:18 AM
There used to be a problem in Vue 4 (pro and espirit) where materials with the same name on different figures/props were not imported properly, this may be a pain but import each unit seperatly into vue and set the room up there would be your best option..
Of course I have never had this problem since I switched to Vue Infinite... it collapses materials, but everything imports in where it belongs and shows up.. but that's an expenisve fix..
mes
