Wed, Jan 22, 11:37 PM CST
Subject: Applying a magnet to selected material zones?
EnglishBob ( ) posted Fri, 23 June 2006 at 3:50 AM · edited Thu, 29 August 2024 at 4:34 PM
This is embarassing - I was sure I knew how to do this, but it didn't work when I tried it. I want to apply a magnet to certain material zones on a figure: in this case, V3's inner mouth, tongue, teeth and gums. This is what I thought I should do, but it obviously isn't since it doesn't work. I open the grouping tool, create a new group called Mouth. Then I add the materials that I want to magnetise to that group. I thought that I should be able to apply a magnet to this new group, but I can't find how to do it. Maybe my assumption was wrong, or maybe I missed a step. Put me out of my misery, please... 😕
Gora ( ) posted Fri, 23 June 2006 at 4:06 AM
ummmm.... Ive never morphed a group before, I usually do a single body part at a time.... but I can tell you that I usually parent the part to the magnet after setting the positions etc.... I find this helps quite a bit. Otherwise Id suggest trying to find a reference in Travellers tutorials on RDNA, if I remember correctly I think there may have been something of the sort in one of them....
Hope this helps
"If toast
always lands butter-side down, and cats always land on their feet, what
happens if you strap toast on the back of a cat and drop it?"
Steven Wright
jancory ( ) posted Fri, 23 June 2006 at 5:53 AM
after you create your new group & the new magnet, just go to the Magnet Zone's properties & check Group there---Mouth'll be in a little dropdown list---& that should do it for you.
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
EnglishBob ( ) posted Fri, 23 June 2006 at 1:36 PM
Thanks Jan, I'd never have found that by myself. It worked a treat. When's your birthday? :)
jancory ( ) posted Fri, 23 June 2006 at 3:46 PM
you're quite welcome--it's the least i can do for all the cool stuff of yours i use every day....
ps i no longer do birthdays......
 My Freebies
