Fri, Nov 8, 4:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
Subject: Strange Poser 6 Texture Problem
White Raven ( ) posted Fri, 30 June 2006 at 9:51 PM · edited Fri, 08 November 2024 at 3:41 AM
  After loading a texture (I am using Laura, the female MilTeen), the texture map shows up shrunk  down in the area I have selected rather than loading an area to the model. I know I'm doing something silly, could someone give me some advice on how to fix this?
Thanks in advance,
White Raven
JunkoH ( ) posted Fri, 30 June 2006 at 10:15 PM
sounds like you have applied a head map to a body material zone
White Raven ( ) posted Sat, 01 July 2006 at 12:07 PM
 Thanks, Junkoh - It seemed like no matter what I do the entire map shows up - I had the torso selected and was trying to work with that but I will keep trying. I want to give away this texture as a freebie once I'm done. :)
Thanks,
White Raven
diolma ( ) posted Sat, 01 July 2006 at 1:34 PM
Try loading any V3 texture onto Laura (they share the same UV-Mapping). If the same thing happens, then the chances are that, somehow, you've lost Laura's UV-Mapping...
BTW - there are hundreds of V3 textures avaiable for V3 in Free-stuff, if you don't have any yourself...
Cheers,
Diolma
White Raven ( ) posted Sat, 01 July 2006 at 11:26 PM
Thanks, Diolma, I tried that. I can load a V3 texture fine, It's only when I try to load a texture using the Preteen Texture in the Material Room that I get this. I'm not sure what I'm doing wrong. :(
Thanks in advance,
White Raven
JunkoH ( ) posted Sat, 01 July 2006 at 11:38 PM
The Mill Preteen textures do not fit Laura 3
They do fit Laura PT
White Raven ( ) posted Sat, 01 July 2006 at 11:46 PM
 Thanks for replying, Junkoh. I'm kind of confused on the difference though, I have Luke and Laura, is Laura PT part of that package or do I need to get something new?
Thanks,
White Raven
JunkoH ( ) posted Sun, 02 July 2006 at 12:15 AM
Attached Link: Luke and Laura Product Page
You should have both Luke and Laura PT.  The PT versions use the old style Mill PT textures. Laura 3 can take any Unimesh texture.  You have to decide which figure you are going to work with and use the appropriate template or seamguide.
White Raven ( ) posted Sun, 02 July 2006 at 12:34 AM
I've used the Laura template, but I'll keep trying. Thanks, Junkoh. :) It's still loading the entire template image into the diffusion map when I try and place it there for texture mapping. Is that the problem? Is there some tutorial I can use so I'm not such a pest? Poser 6 is kinda confusing to me, but I really want to master it. :/
Thanks,
White Raven
JunkoH ( ) posted Sun, 02 July 2006 at 12:56 AM
Try looking through the tutorial section here.  Maybe also Dr. Geep.  I know that Poser Pros has a few in their forums.
