Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
Attached Link: Luke and Laura Product Page
You should have both Luke and Laura PT. The PT versions use the old style Mill PT textures. Laura 3 can take any Unimesh texture. You have to decide which figure you are going to work with and use the appropriate template or seamguide.I've used the Laura template, but I'll keep trying. Thanks, Junkoh. :) It's still loading the entire template image into the diffusion map when I try and place it there for texture mapping. Is that the problem? Is there some tutorial I can use so I'm not such a pest? Poser 6 is kinda confusing to me, but I really want to master it. :/
Thanks,
White Raven
After loading a texture (I am using Laura, the female MilTeen), the texture map shows up shrunk down in the area I have selected rather than loading an area to the model. I know I'm doing something silly, could someone give me some advice on how to fix this?
Thanks in advance,
White Raven
