Mon, Dec 23, 2:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: Can you all please help me learn this?
Debbie M. ( ) posted Fri, 13 April 2001 at 8:12 PM ยท edited Mon, 23 December 2024 at 2:24 PM
I'm trying to learn how to use prop scenes. I'm trying to use ron molina's fabulous Camelot prop here, and get a figure on the balcony area. I just don't understand how to get her the same scale as Camelot. I've purchased the poserworld cd's and it also has some exquisite scenes, and I just don't understand how to use this. I can create a texture, morph a character, dress them, use simple props... but when it comes to this, I'm simply dumb founded :( Any assistance would be greately appreciated. Thanks in advance!! Deb
Debbie M.
the3dwizard ( ) posted Fri, 13 April 2001 at 8:21 PM
Try this. Select body at the bottom where you select body parts and use the scale dial.
lalverson ( ) posted Fri, 13 April 2001 at 8:27 PM
I use the TLAR method (That Looks About Right) for items that are supposed to be big genarrl I start at 600% and see where to go from there. I also turn the prieview mateial off on the prop if there is one so I can better guess.
Debbie M. ( ) posted Fri, 13 April 2001 at 8:32 PM
the3dwizard, I've tried that... but everytime I scale her down... I lose her, and can't find her anymore. I really feel like a total idiot :( But this is something that I've been REALLY wanting to learn, and now that I have the stuff to learn with, I just don't understand. lalverson.... the preview material is none.... is that where I'm supposed to be looking? in the render/materials. I'm so sorry that I KNOW I sound so DUMB here, but I just can't figure this out.... and I REALLY want too so badly. Thanks guys!! Deb
Debbie M.
the3dwizard ( ) posted Fri, 13 April 2001 at 8:43 PM
Try setting you camera to point at her. Select camera by clicking on the ball with four arrows. Then in object menu select point at then from the list select her hips. Then when you rescale and zoom in it will zoom to her.
Ladyfyre-graphics ( ) posted Fri, 13 April 2001 at 10:51 PM
Hi Deb, if you select the litle arrow on your preview styles and select "element styles" you can the select the scenery prop and click on "outline style" that will make the prop see through but keep your main figure solid so that you can see where you are pputting her in the castle, at least thats what I do with stuff like that anyways :) Alla
www.ladyfyre-graphics.com
  • Poser freebies, tutorials and articles, gallery and lots of stuffage for the Poser and Daz|Studio Horses!
Debbie M. ( ) posted Fri, 13 April 2001 at 11:24 PM
Thanks the3dwizard, and Alla.... those tips are helping :) I WILL figure this out ;o) Thanks again!! Deb
Debbie M.
-renapd- ( ) posted Sat, 14 April 2001 at 1:56 AM
Site Admin
It will also be a lot easier if you just rescale the camelot prop to be as big as you wish and still retain your figure at the center of the scene so you never loose it! :o)
[[MyGallery] [MyStore]
"Collect moments, not things."
angola ( ) posted Sat, 14 April 2001 at 9:26 AM
Yeah I'm always losing everything especially when importing objects. If the castle is an imported obj file then set size to 100% of figure in the import window and you're not going to be out by a factor of ten. If it's an object or a prop, try checking that x,y, and z trans are at 0 and drop both figures to the floor. If you still can't see your damsel then she's probably lost inside the castle. In the hierachy editor you can click on the eyeball next to the castle and bingo it disappears revealing your figure. (you can also 'disappear' your castle in its properties window, but you may have to repeat the operation for each of its component parts). Once you've found her you can scale as others have said above. angola
