Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
In my experience, the easiest place to go wrong is in the
choices I've circled here. Maybe you had 1 in the 'Last Frame',
or maybe you entered 30 (or whatever your total was) in the Skip blank?
The latter would cause Poser to skip everything after frame 1.
My python page
My ShareCG freebies
Sorry, I didn't make myself clear. I rendered the movie OK but noticed a few inconsistancies that needed to be corrected. I needed sleep badly by then so saved the scene so I could continue editing later. When I opened the scene again, all that displayed was the first frame, all the others (60 in all) had disappeared!!! Does this mean that each frame (or keyframe) will have to be saved as a seperate file to enable further editing. Hoping this isn't the case and that there's an easy way to do it.
Are you sure they are all gone? When I first saved an animated scene, I panicked and thought I had lost all the frames, but I didn't check the animation frame slider thingy (the technical name for it I am sure) at the bottom, when I slid it fto the right I had all my frames back again. Since then, I have saved many animated scenes (some with 300 + frames) and haven't lost any frames. Maybe you could see if they are really still there for you?
Needless to say I'm new to this, but I spent hours doing an animation the other night and thought I saved the complete sequence but when I re-opened the file, there was only the first frame. What did I do wrong?
