Tue, Jan 14, 6:23 PM CST
Subject: quick question - i'm ashamed
circanow73 ( ) posted Thu, 06 July 2006 at 10:38 AM · edited Tue, 14 January 2025 at 6:46 AM
hi everyone, shane here from annapolis md
i just started using VUE, and I mean about an hour or two ago. I am trying to create my first scene, i have some experience with lightwave and maya. i am doing a simple atmosphere, a few mountains, and im popping a few square/rectangular polygons to serve as buildings, using some of the buildings textures. i cant believe how easy this is. can i apply one texture to the sides of the polygons, and a different color texture to the top of the polygon. i know i could just lay one polygon over the other but i want to know if you can apply different colors/textures to different sides of the same polygon??
any help would be appreciated. thanks ini advance.
shane
DVcreator ( ) posted Thu, 06 July 2006 at 12:51 PM
Generally state what version of Vue your using helps, And thats what this forum is here for asking Q's. In the backroom (lookup at the header) there are plenty of tutorials I have found very helpful...
Okay so you want to put a different top on a (cube) building, most of the models have a (+) symbol in the right side viewer, this will expand to individual components of the object. click a highlight on a component and change its texture.
And play with some of the free models in the FreeStuff ....
hope it helps
R
chippwalters ( ) posted Thu, 06 July 2006 at 9:03 PM
Shane,
I'm not sure exactly what your question is, but if you're asking, "Can I put a different map on each side of a cube?", then the answer is NO. But you can use parametric mapping projection to put a single map which wraps completely around the cube. You 'll need to check the docks for that.
You can also export the cube as polys, then import it back, and then separate it into separate polys, which then can each have a map applied to them.
Also, I know it's the in thing to do-- not use any punctuation, or capitalization in your messages. But, they do make them very hard to read. Perhaps you might take a second and consider making them more readable for those who wish to help you.
best,
Chipp
circanow73 ( ) posted Fri, 07 July 2006 at 6:50 AM
Thanks Chipp
The exporting and then importing sounds like the quickest way to get what I'm looking for.
And I promise to capitalize my letters, cross my tees and dot my eyes too. And to never ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever  ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever ever end my sentences with a preposition.
Thanks again.
Shane aka The "In" Guy
