Wed, Nov 20, 10:28 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Wind?
Jonj1611 ( ) posted Sat, 08 July 2006 at 2:28 PM ยท edited Tue, 24 October 2023 at 4:09 PM
Hi,
I just upgraded to Vue 5 Infinite today. I was looking forward to checking out the wind effect on trees.
Now the manual says their will be a triangle in circle when looking at the selected plant in top down view. However, I cannot see this icon at all. Any ideas of what I may be doing wrong?
Thanks
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
nruddock ( ) posted Sat, 08 July 2006 at 2:47 PM
Have you checked "Enable wind (on a per plant basis)" in the Atmosphere editor on the Wind tab ?
Jonj1611 ( ) posted Sat, 08 July 2006 at 3:13 PM
Probably not :)
I was following the manual, must have missed that bit :)
Will look now
Cheers
Jon
nruddock ( ) posted Sat, 08 July 2006 at 3:58 PM
The manual doesn't mention in the "Applying Wind" section on page 108.
It is described on page 202 in the "Wind Tab" section.
That setting does appear to be off by default (for me any way).
diolma ( ) posted Sat, 08 July 2006 at 4:22 PM
"The manual doesn't mention in the "Applying Wind" section on page 108.
It is described on page 202 in the "Wind Tab" section."
This is even more annoying if you have a manual like mine, which is falling apart at the seams, and its leaves keep fluttering away on the slightest breeze...
(I MUST find a cheap way of getting the manual ring-bound!)
Cheers,
Diolma
nruddock ( ) posted Sat, 08 July 2006 at 4:34 PM
Quote - "The manual doesn't mention in the "Applying Wind" section on page 108.
Cheers,
Diolma
Hopefully that won't happen to the PDF version ๐Ÿ˜‰
Now if only the index had internal page jumps ...
