Thu, Jan 30, 11:23 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: conforming the clothes
gemino77 ( ) posted Wed, 12 July 2006 at 10:18 AM · edited Wed, 29 January 2025 at 11:10 PM
Hello,
what can i do to conforming the clothes to the modify body?
I don't know.
There is someone can help me?
thanks in advance
thefixer ( ) posted Wed, 12 July 2006 at 11:57 AM
It looks like the chest and breast morphs are your problem here. Check waht settings your figure has, i.e. what breast size dials etc. are modified. Then see if your clothing item has the same morphs and adjust them to the same as the figure morphs, job done!
If the clothing item doesn't have the same morphs then you're pretty much in the doo-doo unless you have a bit of kit by netherworks that can put the morphs into the clothing, forget what it's called now but it's a brilliant bit of kit!
You could try increase the xyz scale and possibly the taper dial, workd sometimes but not always!!
Injustice will be avenged.
Cofiwch Dryweryn.
nickedshield ( ) posted Wed, 12 July 2006 at 12:28 PM
Three more suggestions: 1. You can use The Tailor from Daz 2. You can use Wardrobe Wizard from philc.net 3. You can use magnets Poser built in.
lululee ( ) posted Wed, 12 July 2006 at 1:17 PM · edited Wed, 12 July 2006 at 1:19 PM
Hi **gemino77**
I have the same dress. It does have all the dials you need to fit it to your model. They are found in the "body" part of the dress.
   Unfortunately "conforming" usually means it fits the standard V3 model. If you alter her body shape you also have to alter the clothing dials to fit her custom shape. I altered the breast 8 dial in this and added some "wind" to her skirt to stand out more.
I also injecrted the "nipple gone" into my V3 and set it to 1.00 so there was not naughty nipple pokethrough.
Hope this helps.
cheerio  lululee
thefixer ( ) posted Wed, 12 July 2006 at 1:36 PM
NO NAUGHTY NIPPLE!!!!
Ye Gods what next!!!!!
Cofiwch Dryweryn.
dbowers22 ( ) posted Thu, 13 July 2006 at 6:44 AM
Too bad for Janet Jackson she didn't have her "Nipple Gone" set to 1.000
