Sun, Feb 2, 10:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: mtl filess
Anniebel ( ) posted Fri, 14 July 2006 at 4:28 AM · edited Thu, 23 January 2025 at 3:45 AM
When you export & save an object from Poser as a wavefront OBJ what are the mtl files poser creates along with the OBJ file & do I need to keep them?
Thanks
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Gora ( ) posted Fri, 14 July 2006 at 4:51 AM
as far as I know you can safely delete them, without it affecting anything....
"If toast
always lands butter-side down, and cats always land on their feet, what
happens if you strap toast on the back of a cat and drop it?"
Steven Wright
jancory ( ) posted Fri, 14 July 2006 at 6:19 AM
poser writes a reference to the  mtl file inside the object file.  some programs, bryce for instance, want you to find that file before import.  so in some cases it helps to keep them.  it's basically a listing of the materials used in the object.
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
Anniebel ( ) posted Fri, 14 July 2006 at 6:52 AM
Ok thanks
Helen Keller
Spanki ( ) posted Fri, 14 July 2006 at 9:29 AM
It tells other apps the name of the texture map files and the color settings to use for each material.  It's a simple text file, so you can load one up in Notepad and take a look at it if you want.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
