Fri, Jan 10, 7:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: help w/ image map and math values please...?
DarkEdge ( ) posted Fri, 14 July 2006 at 4:37 PM · edited Fri, 10 January 2025 at 5:45 PM
hi all!
i thought i read somewhere that you can alter an existing image map (the color) with a math value ...is this true?
and if so lets say that i wanted to slightly darken and/or lighten a map...what values would i start with? also, is it a math value or something else to do this?
thanks all!
gmadone ( ) posted Fri, 14 July 2006 at 5:06 PM
The texture strength on the image node may do what you want.
a math node will grey scale your image so if my first solution didn't work you might use a colormath node to add or subtract a little grey.
Ajax ( ) posted Fri, 14 July 2006 at 5:49 PM
If you're using Poser 6, then the node you want is the color math node.  Set it to the bias function to adjust brightness or the gain function to adjust contrast.  Run your texture map into value 1, then use value 2 to make the adjustment.  For bias/gain 50% grey in value 2 is no change, less than 50% is darker/less contrast, more than 50% is brighter/more contrast.
diolma ( ) posted Fri, 14 July 2006 at 6:07 PM
"If you're using Poser 6, then the node you want is the color math node.  Set it to the bias function to adjust brightness or the gain function to adjust contrast.  Run your texture map into value 1, then use value 2 to make the adjustment.  For bias/gain 50% grey in value 2 is no change, less than 50% is darker/less contrast, more than 50% is brighter/more contrast."
This also works in P5.
There are lots of ways to alter the way an image map works in P5/6, (eg, to darken an image, just plug it in as usual, then reduce the value to less than 1.0, or to lighten it, increase the value above 1.0) - or change the diffuse node's colour (which can also add a "colour cast" to the texture) ....
Alas, I' m in no condition to add extra advice - maybe tomorrow... -- must go to bed now...
Cheers,
Diolma
