Tue, Feb 4, 11:54 AM CST
Subject: Poser-Bryce Utility - PC Only
jade_nyc ( ) posted Mon, 09 April 2001 at 12:55 PM · edited Tue, 04 February 2025 at 8:43 AM
Attached Link: C. J. Cigas's Grouper Utility
Just wanted to let everyone know about a great utility I found for importing Poser objects into Bryce. Grouper 1.1 Grouper is a small helper application designed to make importing Poser models into Bryce easier. There are two basic problems when importing these models. Imported models look different in Bryce than they did in Poser When you export a model as on Wavefront OBJ, Poser does not include all of the material properties. Neither does Bryce support importing these properties. Materials must be manually adjusted after the model is imported for a realistic effect. During import all bump and transparency information is lost. Once imported the process of adjusting materials can be time-consuming Depending on the options you chose when you exported the model it may contain up to a hundred separate objects that must be correctly mapped and adjusted. For example, if you export using the default options your model will contain 20 separate objects in Bryce. Unfortunately, the names of the objects are lost during import so it's hard to know that Figure_1_20 is actually the hair object. If you chose to export the body part names, you imported model will contain 88 separate objects. The trouble here is although you can identify each body part, many of those parts must be mapped in the same way. Aside from adjusting 88 separate materials, you have to make sure that, for example, the abdomen and the chest are mapped in exactly the same way. Grouper reads the OBJ file you export from Poser and breaks it down into its individual polygons, then groups them into objects based on their material. All mapping information is retained and the material names are sufficiently descriptive to make material adjustments in Bryce quick and easy. Jade
KenS ( ) posted Mon, 09 April 2001 at 2:41 PM
sounds extremly useful, thanks for sharing the link, Im downloading now. Ken
jade_nyc ( ) posted Mon, 09 April 2001 at 3:11 PM
it works great! you only have to do a little tweaking on the materials and it renames the meshes for you - no more figure_1_1, etc. Woohoo! Jade
Swade ( ) posted Tue, 10 April 2001 at 10:28 PM
Thank you for that link jade nyc. :o) I have downloaded it and am gonna try it out. Looks like a very useful little utility. Swade
There are 10 kinds of people: Those who know binary, and those who don't.
A whiner is about as useful as a one-legged man at an arse kicking contest.
thenodemaster ( ) posted Wed, 11 April 2001 at 6:46 PM
TNX will check it out! thenodemaster
Ladyfyre-graphics ( ) posted Sun, 15 April 2001 at 9:13 PM
Thankyou so much for the heads up on this! I downloaded it and guess what - it actually works for my freebie Vue 2 as well, makes it soo much easier!
www.ladyfyre-graphics.com
  • Poser freebies, tutorials and articles, gallery and lots of stuffage for the Poser and Daz|Studio Horses!
