Tue, Nov 12, 9:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:45 pm)
Subject: CDI Morphs ??????
ashley9803 ( ) posted Tue, 04 July 2006 at 9:24 PM · edited Sun, 10 November 2024 at 6:20 AM
Thinking of purchasing Kioki for A3. Daz states "Numerous head and body morphs utilizing injection technology (for CDI morphs only).
http://www.daz3d.com/shop.php?op=itemdetails&item=3067
There are 183 head/throat morphs and 45 body morphs.
Are these morphs pz2 files that I can use like normal from my Pose Library?
What exactly are CDI morphs?
Would appreciate any advice.
nruddock ( ) posted Tue, 04 July 2006 at 9:56 PM
CDI is "Capsces Digital Ink", the person that produced this morph set.
They most likely mean that the set contains INJ and REM files for the morphs in the set.
Tunesy ( ) posted Tue, 04 July 2006 at 10:10 PM
I've had Kioki from CDI for quite a while and think it's a terrific product.  Between that and Netherworks 'Aiko-X' morph sets I can't imagine needing any other morphs for Aiko.
Puntomaus ( ) posted Wed, 05 July 2006 at 5:14 AM
The Kioki Cr2 has lots of additional new morph channels especially for the CDI morphs that come with the pack. This means in order to use the CDI morphs you would have to always use Kioki and not the default Aiko.
ashley9803 ( ) posted Wed, 05 July 2006 at 5:11 PM
Thanks for your help.
novelist999 ( ) posted Thu, 20 July 2006 at 2:03 AM
Quote - I've had Kioki from CDI for quite a while and think it's a terrific product.  Between that and Netherworks 'Aiko-X' morph sets I can't imagine needing any other morphs for Aiko.
Tunsey,
You sound like you're experienced using Capsces' morphs, so I have a question for you.
I'm trying to render some images with Capsces' Chubblies, and there are white pixels all around the images I've rendered, because the Mil3 Baby's textures aren't big enough for the morphed body.  Do you know of a way to get around this besides making a new texture for the Morphed baby?
I really love her morphs, but I've steered away from using them because of this problem.
Thanks,
Bobette
nruddock ( ) posted Thu, 20 July 2006 at 3:06 AM
Quote - I'm trying to render some images with Capsces' Chubblies, and there are white pixels all around the images I've rendered, because the Mil3 Baby's textures aren't big enough for the morphed body.  Do you know of a way to get around this besides making a new texture for the Morphed baby?
I've seen it suggested that swapping the Mil3 Baby's UVs for those of V3 will do this.
You'll need a version of UVMapper.
Load V3's OBJ, and export the UVs.
Load Mil Baby's OBJ and import the UV's you just saved.
Save the OBJ with a different name.
Edit a copy of CR2 to point to the new OBJ.
Tunesy ( ) posted Thu, 20 July 2006 at 5:42 AM
...what nruddock said.  That sounds more like a UV issue than a morph issue.
novelist999 ( ) posted Thu, 20 July 2006 at 5:46 AM
Okay. Thanks. I'll try it. :-)
Bobette
JOELGLAINE ( ) posted Thu, 20 July 2006 at 8:32 AM
The texture is at fault, not the morph.  There is no morph anywhere that can cause a texture to slip.  One other thing you could try: Open the texture in question in a paint program and extend the texture for a couple pixels in the direction of the visible seam and just save it and reopen poser and click the little black arrow-head at the top right of the preview window and click 'Reload Textures' and see if this helps any.
I cannot save the world. Only my little piece of it. If we all act together, we can save the world.--Nelson Mandela
An  inconsistent hobgoblin is the fool of little minds
Taking "Just do it" to a whole new level!
