I just bought the "Vue 5/Poser 6/Mover 5" bundle so I didn’t have any previous installation, but I did notice that on the Application CD there is a folder called "Add-onsMover" and in there was an installer called Mover5ForVue5Installer.exe. The About.txt says:
---- About.txt ----
The Mover5ForVue5Installer application is designed to let you use your Mover license within Vue 5.
So it looks like you need to run this installer and supply your Mover 4 serial number to unlock it. Hope this helps.
~jr
I have just down loaded the Vue 5 upgard from Vue 4 - I also have Mover 4 which when you down load the latest update it also upgrade Mover. Now it says that it will upgrade to Mover 5 - although in Vue 4 it still shows it as Mover 4 when you go to use it. Anyway my question is how the hell due I install Mover 4 to the Vue 5 upgrade? as I thought I had instilled it - but when I go to animat to shows as ANIMATION WIZARD - my next question is once I have finally managed to install Mover 4 to Vue 5 - how/where do I get the upgrade to Mover 5 and install it?
I hope someone can help me with this...
Bushy
