Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 24 6:31 am)
Have you verified that the morphs that you want to add to the figure are compatible with the figure itself? If yes, then try renaming the figure in the scene. Sometimes Poser becomes confused when the figures are named 'Figure 1,' 'Figure 2,' etc. Chose the figure in the drop down figure menu, and then chose 'body' in the drop down body parts menu. From the toolbar, choose 'Object,' and then 'Properties.' In the dialogue box, where it says 'Figure...,' type a new name (Call the figure Mike, or Joe, or even Erasmus, if you want to be exotic. If you want to be exotic with a female figure, you can call it Yochevet, after the mother of Moses). The principle here is to give Poser something more than just a sigle didgital number by which to distinguish the different figures.
This may solve your problem, or it may not; but at least it's a new meathod to try.
Yours truly,
David P. Hoadley
I'm guessing this is related to a millenium figure, i.e. one of the DAZ ones. There is some quirk with them that doesn't allow this, can't remember why although I had though P6 had got around it.
The best way around it is to bring in 1 figure, morph it and save it back to your library under another name with all the morphs, do that as many times as you like then bring them into your scene as you like!
Injustice will be avenged.
Cofiwch Dryweryn.
Not a dumb question at all, we were all new once [lol].
Preferably just have your morphed figure in the scene on it's own.
Go to the top level of your Character or figure library pallete and with your morphed figure selected, click on the little [+] sign in the bottom corner of your library pallette.
You'll get a couple of questions about morph data or some other stuff, can't remember which, usually just say "yes" and the whole figure will be saved to your library to be used as much as you want.
I usually do this when I'm working on a series of images featuring the same character, like a story you know!
Hope that helps, need any more help just shout!! [IM if you want!].
Cofiwch Dryweryn.
Make sure that you have chosen the figure's 'Hip' before you click on the + sign, otherwise you might end up saviing an empty figure (one not pathed in the Cr2 to any figure's geometry).
An example, if you've chosen a figure, but then played with your light settings before saving, it'll be your light settings that your saving as a figure, rather than the figure itself.
Yours truly,
David P. Hoadley
if i try and save the figure to my library it looks like it does it, it ask me a bunch of question and stuff but when i try and load that again it looks like it only saved the morph data and not the whole figure......
i cant load what i saved, it inject it into whatever figure i have open.
am i doing something wrong????
Did you click opn the 'Hip' before saving? If not, then see my post above. THAT is the answer to your question.
David P. Hoadley
Anothrer thought, which check mark are you clicking on when you go to load your second figure, the single or the double? If you click on the single, it replaces your existing figure with a new one, if the double, it adds an additional figure to your scene.
David P. Hoadley
Behold my dear Watson, we are finally getting to the bottom of it.
hi there!
maybe some one knows what is going on here.......
when i have more than one figure in my scene and i want to apply body morphs to the second figure they dont work!! i have no idea why! its fine with one figure but as soon as a second one comes in it goes to hell!!!!
does anyone know why this is happening?
thanks!
