Forum Moderators: RedPhantom
Why don't you just try naming your new .obj morphcatsuit.obj, then in in the Cr2 there will be 2 places I think where you change the .obj to your new .obj and try it. Make sure the catsuit is zeroed properly before you start ie hip dials all zero and body dials all zero before dynamicing it. Good luck, lemme know if it works. Love esther
I aim to update it about once a month. Oh, and it's free!
You will need to do the following:-
Though not essential there are tools in the Poser Tool Box that will speed up this process.
http://www.philc.net/PTB_tutorial4-3.htm
Thanks very much for the advice and link PhilC. I've been making FBM's for quite a while now but always appear to have done it the hard way lol. I never knew most of these options on your link existed.
I'm stuck at work at the moment but can't wait to get home and give this a try. I'll post back later with how I get on.
Thanks again!
Phil, Hi. I'm having problems from the start =/ (I'm wondering if it's how I exported the original .obj file.) Step 2. When I click the "spawn props" button, nothing happens. If I click the catsuit and "select all" then hit "spawn props", the whole catsuit is replicated. (I'm wondering if I should have clicked one of the check boxes when originally exporting the figure as an .obj.
Any ideas?
Thanks.
Hi, I've managed to turn the V3 catsuit into a dynamic piece of clothing. After it's been draped over the figure I'd like to take the end result (folds creases etc etc) and turn that into a morph for the conforming suit... Is this possible? Or do the geomitries change as soon as it's made into a single non jointed figure? (.obj) If it can be done, can this be done in Poser on it's own or would I need a different program?
I hope this makes sense.
