Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
I believe you could use Morph Manager, a free utility, to add that morph to the pants
http://www.morphography.uk.vu/dlutility.html
but I believe there are issues with it and Poser 6 - you have to change the version number of any P6 file you wish to open with MM to version 4.01 or version 5
Hope this helps,
Logan
ok it didn't work. What am I doing wrong.
I opened the shirt that has pregnancy morph target and the skirt that doesn't in MM and copied the target and saved the skirt.
Then I opened poser and applied the skirt the pregnancy morph dial is there but doesn't do anything when I turn the dial the skirt doesn't change.
Any suggestions?
Morphs made for one item won't work on another item with different geometry.
Although MM is able to transfer the channels and data for the morphs between items with different geometries, it doesn't convert morphs.
It's primary function is to move morphs between CR2s for items that have the same geometry.
OK it turns out im on either glue, paint-chips, or possibly a combination of both.
I thought I remembered using MM for this task, when in fact, I used The Tailor 1.5 from DAZ3D. It's newest current version is 1.61
http://www.daz3d.com/shop.php?op=itemdetails&item=3679
sorry for the confusion. Have you ever worked with the tailor? Its a great utility, and while its not free unfortunately, it IS currently on sale :)
I aim to update it about once a month. Oh, and it's free!
check the documentation regardng checking "as full body morph" feature.
You may try giving the skirt another run thru the program, selecting all instances of the morph in all body parts affected and applying to skirt differently and saving out with a diff name to test against your first conversion.
Good suggestion with WW esther, I havent any experience with that for applying clothes to custom morph chars yet but there seems to be a LOT of happy excited users of this program so im sure Phil has come thru yet again :)
Ok can someone help me please. I am working on a pregnant V3 and the morphing shirt has the pregnancy morph dial but the skirt and pants don't...How do I get that morph dial for the skirt and pants??
Thanks,
Shannon
