Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
Displacement maps in Vue6 Infinite are an option of the bump area. It means they share the same maps as bumps. If you have a better displacement map than a bump map, you can always turn on displacement and replace your bump map by a displacement map. If you don't have a separate displacement map, you can simply use the bump map to get the effect. All you need to do is increase the depth of your bump map to increase the amplitude of the changes.
Attached Link: Ally Cat
Try using displacement mapping on in P6...you can plug almost any texture into the displacement plug, be sure the RENDER SETTINGS are set to USE it and render... very much the same effect as the example at e-on! I love Displacment ! I used it for fake grass... bumping up wood and even fluffing up a sweater on a poser person in P6! To have the ability in vue is great!Look in my gallery at my Ally Cat (link here) - I even used a degree of displace on her jeans and jean belt... :)
Lyne
Life Requires Assembly and we all know how THAT goes!
Hi all.
I'm pretty novice when it comes to this whole displacement mapping thing but from what I have read it sounds cool and it looks great. My question is, are the actual displacement maps different from the bump maps? For the bump maps now we have black and white images that decide the high and lows, is that the same for displacement maps? If I load up an old scene, can I click an option that turns the bump maps into displacement maps and then just render it out with the new look or are all new displacements maps required? I understand that some maps might need adjustment as they may unintentionally destroy an object visually beyond what I was expecting. Thanks.
