Tue, Jan 21, 10:35 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Underwater torpedo wake
Michael_C ( ) posted Tue, 08 August 2006 at 7:39 AM · edited Mon, 06 January 2025 at 2:49 PM
Attached Link: Underwater series
I'm putting together an underwater scene with a torpedo running and looking for ways to do the 3D torpedo wake in either Carrara 5 Pro or Poser 6.  My intial attempt in Poser was a smoke object turned horizontal.  This sort of worked but will need several replications for a substantial wake.  It seems like a volumetric solution would be better.  I'd like some twists and turns in the wake and it will be fairly long.  Any suggestions?  Thanks.
(This is for the continuation of the series linked.)
Michael
My Store - My Gallery - My Freebies - My Web Site
bluetone ( ) posted Wed, 09 August 2006 at 9:56 AM
I would think a Particle object that you then animate it's motion with the particles being bubbles and have them set to 'Free' would work out. Give them plenty of 'Life' so that they survive long enough to work, and set them to have a slight negative 'Z' gravity setting so that they float up in the water.
As far as a wake on the surface, LOTS of people have tried many different methods to create a wake. The best that I know of involves creating a 2d video, then using it as a displacement map on the surface of your water.
Let us all know how it all works out for you!
Michael_C ( ) posted Sat, 12 August 2006 at 9:43 AM
Thanks, blue.  I think your suggestion will work.  I don't expect the wakes will be a significant part of the render, but sometimes that attention to detail makes gives a much better result.  Looks like I have some experimantation in front of me.
Michael_C ( ) posted Sun, 13 August 2006 at 1:59 PM · edited Sun, 13 August 2006 at 2:00 PM
I've been fooling with bluetone's suggestion and getting pretty nice results.  However I haven't worked with particle emitters much and I have question.  I've adjusted the gravity effects to cause the bubbles to rise, but they only go so high as if there's a limit.  See the attached side view.  Any thoughts?
Michael_C ( ) posted Sat, 19 August 2006 at 4:15 PM
I did some experimenting and a little thinking and answered my own question.  The apparent bounding of particles is the consequence of physics.  If there is no variation of mass I get the nice cylinder attached.
