As far as the translash is concerned, if you'd like to get an idea of how to create one, try downloading the one available at digital babes. You can find the link in the column on the right under "web ring top 15". It's basically a grayscale image that tells the program what parts to keep solid, and which to make transparent. The way to use it is to apply this transmap texture to the transparency material slot in poser. Then use the transparency sliders to get the effect you want. The poser book the program comes with should have more on transparency. Not sure about the .cr2 files...haven't made any myself yet. Good Luck. Dragontales
Attached Link: http://www.vowel.or.jp/~kozaburo/
Check out the above site, which is Kozaburo's Digital Babes, and download his eyelash transparencies. Set the eyelash color to black, the highlight/ambience/reflective color to black as well, and load the Translash.jpg file you get from Kozaburo in the transparency field. Don't load a texture/bump map for the lashes. Set maximum transparency to 100 and all the other transparency settings to 0. I think Kozaburo has a pic of the map settings in the .zip file. These are just very basic settings and wil get you started, you can tweak them and adjust the color of the lashes, etc once you get them to work. I'm pretty sure the above is correct but I'm writing this from work and don't have poser open so I might have missed something.Hmm, I found the translashes (thanx), however it still blocks off the lashes as one solid clump. I removed the texture map on the material called "eyeLash", set all the colours to black, loaded the translash.jpg as my transparency, set trans Max to 100% all others to 0, and still no joy. Is it concerned that the translash is 2000x2000 pixels, but my skin texture is 3000x3000 pixels?
Attached Link: http://morphs.bbay.com/
hehe. we all made the same mistake, im sorry i forgot to mention that on the p4 woman there are 2 lashes/eyeLash listings. i don't use the p4 nude woman much so it slipped my mind. i suggest you also get kozaburo's hair and textures -- its great stuff. you can get azura/eve4 from the link above -- its a superior model to the p4 nude woman and best of all its free!This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
