Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
However, those shadows that lay infront of the lamps maybe be caused by another light source... you have to go to the light properties and knock out that source of light.....
nice lamps....
nice lamps....
Yeah, turned out it was the sun.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Quote - Nice lamps. personally I would knock the intensity back by about half and bump the edge softness up to between 25 - 45 just to soften around the outer edges.
Cheers
GG.
How do you get Edge Softness to activate?
Measure
your mind's height
Measure
your mind's height
Measure
your mind's height
Quote - > Quote - How do you get Edge Softness to activate?
Can't use it with a radial light. Works with any other kind of light.
Aha, could explain why I hardly ever use it then. Since I mostly use radials... with just the occasional spotlight.
I have been havering between radials and spotlights for this lamp - do you think it might be better with a spot then?
Measure
your mind's height
The pools of light from the spotlights looks great but those lamps with spotlights in them don't look so good as lamps.
The lamps with radials in them look great as lamps, but the light they cast has odd parallel lines in it...
Help?
Oh and the redish sodium lamps are still too pink.
Measure
your mind's height
Sorry it took so long to answer (- more problems with my laptop - now it has to go away for repairs, so still using husband's laptop.)
I tried a few things, and it turns out that the lines were caused by the edges of the lamp glass - turning off "cast shadows" for that material cured that problem.
I do already have a fairly high ambience on the bulb and filament - didn't try additive, I'll try that and increasing the ambience too... Thanks for the suggestion.
Measure
your mind's height
On the red side of the street, the radials are in the middle, and I think I like those best.
But they all look better now, so thanks very much for your help, dvlenk6.
Measure
your mind's height
nice render and I like the shag rug on the floor......
The what?
It's supposed to be a cobbled street, is it wrong? How can I improve it?
Measure
your mind's height
Looks odd to me with that sort of photographic reflection-ish thing on the ground.
The shadows are okay but that bit looks odd - is there anyway to get rid of that without getting rid of the shadows?
Measure your mind's height
Fran's Freestuff
http://www.FranOnTheEdge.com
