Wed, Feb 5, 10:23 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Render Nodes and Extensions
vasseur7 ( ) posted Mon, 21 August 2006 at 1:47 AM · edited Wed, 05 February 2025 at 9:33 AM
Is it required to have any third party Carrara plug-ins installed on the Computer that you are using for a Render Node, or does the main computer wiht Carrara Pro application take care of that. I am thinking of shader extensions like: Enhance C
ewinemiller ( ) posted Mon, 21 August 2006 at 6:15 AM
Hi,
They need to be installed on the render node. Also keep an eye out, some will pop serial number dialogs up the first time you render something on the node. That may stall your render node.
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara and LightWave plug-ins
MarkBremmer ( ) posted Mon, 21 August 2006 at 6:33 AM
Just to clarify, you won't need to purchase the extention for each node. Simply duplicate, install it on the node and you're good to go.
vasseur7 ( ) posted Mon, 21 August 2006 at 9:13 AM
Great! How about Shaders created from those extensions? Does it just pull the shader data from the main computer? I do not really see a way of installing the shaders if it was necessary. Thanks again for your help. =-) CV
MarkBremmer ( ) posted Mon, 21 August 2006 at 9:27 AM
As long as the extension is installed on all nodes, the shaders on the source machine will render correctly during a network render.
