Fri, Jan 10, 10:59 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 09 9:55 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Switching Between Cameras For Render
Enivob ( ) posted Mon, 28 August 2006 at 10:21 AM · edited Fri, 10 January 2025 at 8:23 PM
Hi All,
A simple question, how do you switch between cameras?
When I render via F12, I always get the first/default camera in the scene.
I have tried the align view to new camera, but that does not seem to affect the camera that is doing the render.
Thanks
Enivob
damir_prebeg ( ) posted Mon, 28 August 2006 at 11:14 AM
Select that new camera and press CTRL+0.
But if I may notice, you have a lot of questions so I suggest that you get Blender's manual available here http://www.blender3d.org/cms/Documentation.628.0.html
It's a bit outdated but very helpful and there you'll find a lot of stuff that you are asking here, and a lot more. You can also look at Blender wiki http://mediawiki.blender.org/index.php/Main_Page where you can find a lot of tutorials and similar stuff.
Cheers!
Enivob ( ) posted Mon, 28 August 2006 at 12:04 PM
Thanks Damir,
Have you actually tried the CTRL-0?
I did that, but it did not seems to work. I still got my original camera when rendering. You can also access that via the Space Bar menu. I thought it strange...
I have been reading the docs quite a bit. I downloaded the HTMLs over the weekend.
damir_prebeg ( ) posted Mon, 28 August 2006 at 2:04 PM
Yes, I have tried CTRL+0.
But, have you actually added a new camera to your scene?
Got to Add menu and select Camera. New camera will be crated at position of 3D coursor. Then press CTRL+0 to set active camera to that new camera. Now press NUM7 and then pres CTRL+ALT+0. Your new camera will be aligned to top view.
And for fun, you can press ALT+0 and you'll switch default camera back to first camera.
Cheers!
Silgrin ( ) posted Tue, 29 August 2006 at 3:29 AM
And first of all, hit Ctrl 0 when the mouse cursor is in the 3D window:) If you see the view has changed with Ctrl 0, it should also change the render camera.
damir_prebeg ( ) posted Tue, 29 August 2006 at 3:11 PM
Quote - And first of all, hit Ctrl 0 when the mouse cursor is in the 3D window:) If you see the view has changed with Ctrl 0, it should also change the render camera.
Ah, yes, I always forgot to mention that Blender is sensitive to cursor position... :o)
