Fri, Jan 10, 12:16 AM CST
Subject: Poser Pro hier-file question...
ARCHITECT ( ) posted Sat, 21 April 2001 at 2:19 AM ยท edited Thu, 09 January 2025 at 4:18 PM
After upgrading to PPro I'm not able to convert hier-files for my obj-files... I've made several characters using Poser 4.03 but now - Poser Pro - it's not possible any longer... "cannot read valid valid wavefront format geom file curveurve" I tried to convert (test) some of my OLD files again (using the OLD hier files - they have been working fine in Poser 4.03) but this doesn't work too... Is there a new procedure for converting hier-files in PPro? Or is there a bug in the OBJ-import of PoserPro? I've made my props/obj in 3DSMax and this was working fine in Standard Poser 4.03...
JeffH ( ) posted Sat, 21 April 2001 at 2:23 AM
I haven't had any problems with the PPP and converting Hierarcy Files. It must be the 3DSMax OBJ exporter the PPP doesn't like.
Lemurtek ( ) posted Sat, 21 April 2001 at 2:27 AM
You might try loading and resaving the obj via UVMapper. I don't have PPP or 3DSMax, but UVMapper has fixed several weird OBJ files for me. regards- Lemurtek
Mehndi ( ) posted Sat, 21 April 2001 at 3:40 AM
I always load the obj files I export out of Max,into Poser, then I re-export them out using Poser's exporter, before I attempt to do anything at all with them. Since I began doing that, alot of the strange problems I had in the past in several areas, including converting heir files, has gone away. You might give that a try.
