Tue, Oct 22, 9:27 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 4:45 pm)
Subject: Help with Clothing
eaglecop ( ) posted Sat, 21 April 2001 at 10:21 AM ยท edited Tue, 22 October 2024 at 7:37 PM
This is my first Model, How do I get it to appear that the "T-Shirt" is "Tucked" into the "Jeans" Thanks in advance eaglecop
sama1 ( ) posted Sat, 21 April 2001 at 12:26 PM
How about yTrans 0.015 for the "Hip" bodypart of the T-Shirt and the adjust the yScale down to 90%. Also you may need to adjust the "chest", "right collar" and "left collar" to about 95% yScale. These were just quick adjustments you may need to fine tune them to get the results you want. I hope this helps, Sam
hauksdottir ( ) posted Sun, 22 April 2001 at 12:31 AM
Ah, yes, the fun part of dressing our little people. There is a "taper" dial or you can scale the lower part of the shirt so that it will fit inside the jeans. If your guy's skin shows through (check a couple of poses), you can make invisible those parts of his body hidden by clothing. Remember that negative numbers work, too. Sometimes you are tapering plus or minus X degrees depending upon which part or side of the "figure" you are working with. Carolly
