Tue, Nov 19, 8:41 AM CST
Subject: Looking for curled hair
Arien ( ) posted Thu, 14 September 2006 at 7:10 AM · edited Sun, 27 October 2024 at 10:40 PM
I'm looking for curled hair, with the following characteristics:
  • has to be for a MALE (preferably Hiro, but I'm willing to rescale/resize/magnetise to fit); this means, no updos, cutesy or definitely female styles
  • no hairbands, ponytails or the like
  • needs to be long-ish. I can redo the transmap to make it shorter, but it has to go at least down to the shoulders
  • curl needs to be soft/loose, and weight realistically around the head: I've got Frizzled and SpiralCurls, but I'm looking for something a bit "smaller" around the crown
  • no dreadlocks or the like either
  • curls need to be as close to real curls as possible, not just frizz
  • can be either dynamic or a hair prop/figure
  • MUST BE FOR COMMERCIAL USE
I've been looking at Sharmane Hair, but it has the same issue I find with Frizzled and SpiralCurls, in that the top of the head is obviously styled to give a bigger hair look. This is also very "feminine" and doesn't work for what I need it. Something like Neftis' AngelCurlz might work if all locks had the same lenght and there wasn't a fringe. Or April's SpiralCurls, if the curling didn't start at the root and had a somewhat flatter appearance. I've looked at Amante Hair, but again, it's too big at the top, and merely wavy at the bottom.
Something like Adorana's free Calcaria Hair might do it, if I could transfer it to Hiro and make it longer. And ideally, if I could also give it a middle parting instead of a side one, but I can leave with that.
Any ideas of a hair that would work? I know the requirements are a tad hefty, but I also know what I need and what will not do. I've gone through DAZ's, RDNA's and I'm going through here too, but any further input would be appreciated.
Thanks!
My store
thefixer ( ) posted Thu, 14 September 2006 at 7:44 AM
Have you looked at "Estio curls" at DAZ?
Injustice will be avenged.
Cofiwch Dryweryn.
Arien ( ) posted Thu, 14 September 2006 at 7:58 AM
Yes, I've got it. It's way too short and doesn't really have a curl to it, it's just wavy. I've tried the lenghten morph and I end with a wavy mullet :(
My store
Valerian70 ( ) posted Thu, 14 September 2006 at 8:05 AM · edited Thu, 14 September 2006 at 8:05 AM
Attached Link: http://www.renderosity.com/mod/bcs/index.php?ViewProduct=49615
Not full on curly but it certainly morphs to a hard waved effect, sorta like a perm that is about 3 months old and you've been brushing not combing.  Fits a heck of a lot of characters and under $10.  What?  Future Hair by 3Dream - might not fit this particular bill but still a good addition to your hair arsenal, in my ever so humble opinion.
Arien ( ) posted Thu, 14 September 2006 at 8:18 AM
Thanks Valerian. I've considered purchasing Future Hair, but not at the moment.
The problem that I have is that this is for a commission, there's a very particular description of the character I'm depicting, so I have to go with it. If just the wavy thing worked, I would be using WildHair or the like. That's why I gave the whole list above; I'm not being pedantic, I'm just saving myself the hassle of having to re-do a piece because it's not done up to specs.
My store
thefixer ( ) posted Thu, 14 September 2006 at 8:22 AM
There's a really nice looking curly hair at RDNA, can't remember what it's called but it's a dynamic one so it's a bitch to render, might be worth checking it out!
Cofiwch Dryweryn.
thefixer ( ) posted Thu, 14 September 2006 at 8:44 AM
Oops forget that one, it's for the girls, Sorry!!
Cofiwch Dryweryn.
Acadia ( ) posted Thu, 14 September 2006 at 8:45 AM
Why not combine hair? Make one into a prop and parent it, and then use a figure hair as well.  You might be able to find 2 hair styles, that have some but not all of the features you want, and achieve what you want by mixing them together.
MatrixWorkz ( ) posted Thu, 14 September 2006 at 9:02 AM · edited Thu, 14 September 2006 at 9:04 AM
If you have a photo of what you're going for I can see about running off the Dynamic equivalent of the curlz I did for James & Jessi that are in my store and freebie section. I don't have Hiro though so making a skullcap specifically for him is gonna be difficult.
My Freebies
Arien ( ) posted Thu, 14 September 2006 at 9:17 AM
Quote - Why not combine hair? Make one into a prop and parent it, and then use a figure hair as well.  You might be able to find 2 hair styles, that have some but not all of the features you want, and achieve what you want by mixing them together.
I think that would be difficult. While possible to do with styles that have separate "sections" like ponytails, fringers, bangs, etc, the problem here is that the style I'm after has single continous strands from the roots to the tips. So short of doing several renders and merging them, there's not much mixing and matching that I can do.
My store
kobaltkween ( ) posted Thu, 14 September 2006 at 10:44 PM
since the adorana hair is long, it would be fine on hiro.  just make its skullcap fit just within his head.  for dynamic hair , it only really matters precisely where the base is if  you're working with really short  and regular hair, where the difference in length between different places will make a difference (say, for stubble).  i used that hair on jessi (i think it was that one), with no tweaks.
Fyrene ( ) posted Thu, 14 September 2006 at 11:30 PM
If you cannot find exactly what your looking for, trying checking out postwork hair, like ilonas Instant Hair. :)
Arien ( ) posted Fri, 15 September 2006 at 3:19 AM
Quote - If you cannot find exactly what your looking for, trying checking out postwork hair, like ilonas Instant Hair. :)
Thanks. I've been looking at those, to gain some time, but frankly, haven't got any for several reasons:
  • full heads of hair force you to have your figure in a certain angle/camera/size; not good for what I need
  • quite a few of the products don't come with specifications on sizes; of those that do, I think only one of them was suitable for my needs (print).
  • most of them have fixed styles, and there is nothing that fits what I need, as most seem fixed on the long flowy locks
  • all of them have painted highlights, which more than likely won't match the lighting in the image I'm making
I can paint the hair myself, I'm just not looking forwards to it if it can be avoided at all, and I prefer the look of 3D hair over a 3D body, if that makes sense.
Quote - since the adorana hair is long, it would be fine on hiro.  just make its skullcap fit just within his head.  for dynamic hair , it only really matters precisely where the base is if  you're working with really short  and regular hair, where the difference in length between different places will make a difference (say, for stubble).  i used that hair on jessi (i think it was that one), with no tweaks.
That's great to know, thank you very much :)
My store
