Sat, Jan 11, 4:33 PM CST
Subject: Thicker eyelashes?
tvining ( ) posted Wed, 20 September 2006 at 7:22 PM · edited Thu, 01 August 2024 at 8:10 PM
I've been using Poser for quite a while, but the one thing I can't seem to figure out is how to make the eyelashes thicker--they always seem kinda weeny, and using the morphs doesn't seem to help much. Do I need to change the trans maps? I'm using V3. Thanks--T
schtumpy ( ) posted Wed, 20 September 2006 at 10:00 PM
You could try creating your own trans map for the lashes to thicken them yourself.  Are you looking for girth or length?
Tashar59 ( ) posted Wed, 20 September 2006 at 11:47 PM
Different transmaps can help. Look through all your texture for the figure you want to use and see if there is a thicker one. Remember, if it's V3 your using, check all your SP3,A3, and L3/madie textures.
There is also the poser scale factor at work. If your doing a portait/closeup image. Scale your figure up 1000%. Move your camara back with a focus of at least 120.
