Sat, Feb 1, 5:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Test Rig Preparation
nruddock ( ) posted Fri, 22 September 2006 at 7:21 PM · edited Mon, 20 January 2025 at 4:39 PM
See this thread to understand what this is about -> Wrap a sheet in the cloth room
I'm using V3 but any figure should work.
My units are set as cm, so remember you'll need to convert translation dial values if your using other units.
This thread is the first of two (or three) and describes how I setup my test rig.
The test rig by itself isn't that interesting, the technique and what it make possible is.
nruddock ( ) posted Fri, 22 September 2006 at 7:22 PM
Test Rig Preparation 1) Figure
Load figure
Turn IK off
Zero
Drop to floor
nruddock ( ) posted Fri, 22 September 2006 at 7:23 PM
Test Rig Preparation 2) Small Ball prop
Load Ball prop (low poly)
nruddock ( ) posted Fri, 22 September 2006 at 7:24 PM
Set Scale, value not critical, use whatever makes the ball slightly smaller than the palm of the figure's hand, 20% is about golf ball size relative to V3
nruddock ( ) posted Fri, 22 September 2006 at 7:25 PM
Zero all translation dials, then drop to floor
nruddock ( ) posted Fri, 22 September 2006 at 7:26 PM
Export Ball as OBJ
All options unchecked
Delete Ball from scene
nruddock ( ) posted Fri, 22 September 2006 at 7:27 PM
Load a "Square Hi-Res" prop Switch to the Top camera and adjust until you can see the whole prop
nruddock ( ) posted Fri, 22 September 2006 at 7:28 PM
Open the Joint editor window Alter the Centre and End points to (-0.349, 0.0, -0.349) and (0.349, 0.0, -0.349) respectively
Save to the Props library Close Joint editor
nruddock ( ) posted Fri, 22 September 2006 at 7:29 PM
Test Rig Assembly 1) Hand surrogates
Switch back to Main camera
Import SmallBall.obj, all options unchecked
nruddock ( ) posted Fri, 22 September 2006 at 7:30 PM
Front view
Change colour to Red and set Element display style to "Cartoon with lines"
Rename to "RightBall"
Position in middle of right palm (-82, 150, 10)
Bottom view
nruddock ( ) posted Fri, 22 September 2006 at 7:31 PM
Change colour to Blue and set Element display style to "Cartoon with lines"
Rename to "LeftBall"
Position to middle of left palm
nruddock ( ) posted Fri, 22 September 2006 at 7:33 PM
Test Rig Assembly 2) Cloth Plane
Make figure invisible (select Body and uncheck visible)
Switch to front camera
Rotate 90° X
Translate (X and Y) until RightBall is just in the (nearest) top corner
Scale until LeftBall is in a matching position in the opposite corner
nruddock ( ) posted Fri, 22 September 2006 at 7:34 PM
Select cloth plane
nruddock ( ) posted Fri, 22 September 2006 at 7:35 PM
Switch to Top camera Check "Display Origin" (makes it easier to see CP from top) Translate (Z) until ClothPlane is just behind RightBall
nruddock ( ) posted Fri, 22 September 2006 at 7:36 PM
Test Rig Assembly 3) Cloth Plane Magnet
Switch to Main camera
Uncheck "Display origin"
Parent ClothPlane to RightBall
nruddock ( ) posted Fri, 22 September 2006 at 7:37 PM
Create Magnet Select Mag Set Element display style to Outline
Select Mag Base
Set Scale to 100%
Parent to LeftBall
Zero rotate and translate dials
Switch to Front camera
Adjust Y translation so that centre is aligned with LeftBall
nruddock ( ) posted Fri, 22 September 2006 at 7:38 PM
Switch to top camera Adjust Z translations so that centre is aligned with ClothPlane
nruddock ( ) posted Fri, 22 September 2006 at 7:39 PM
Set Parent to ClothPlane
Select Mag
Set Parent to LeftBall
nruddock ( ) posted Fri, 22 September 2006 at 7:40 PM
Switch to Left camera Zero X and Y translation Adjust Z translation until there is no distortion in ClothPlane Switch to Main camera
Select ClothPlane
Set Element display style to Smooth Lined
Select MagZone
Click on "Edit Falloff Graph"
Move all markers up as far as they will go (left click on marker and drag)
nruddock ( ) posted Fri, 22 September 2006 at 7:41 PM
Should end up like this
Delete middle two markers (left click between first and second markers, drag until between third and forth markers, press Delete)
Some fiddling about may be necessary to get line completely flat
nruddock ( ) posted Fri, 22 September 2006 at 7:42 PM
Close Falloff window Scale Mag Zone to 20%
nruddock ( ) posted Fri, 22 September 2006 at 7:45 PM
Select Mag
nruddock ( ) posted Fri, 22 September 2006 at 7:46 PM
Adjust Y translation until there is no distortion in ClothPlane
nruddock ( ) posted Fri, 22 September 2006 at 7:47 PM
Select Mag Zone Set Element display style to Wireframe Adjust scale and translations so that the zone covers just the 9 vertices in the corner
nruddock ( ) posted Fri, 22 September 2006 at 7:48 PM
Save PZ3 !!!
That's the preparation done
Next up is the simulation setup, which will be in a new another thread
fuaho ( ) posted Wed, 27 September 2006 at 9:39 PM
Wow!
I can't wait to start draping after all of that.
Whimsical ( ) posted Sat, 30 September 2006 at 6:23 PM
bm.. thanks for taking the time with this re the mini tute.. is really helfpul information!!! :)
Looking forward to the next installment :)
barrowlass ( ) posted Sun, 01 October 2006 at 2:22 AM
bm
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
Gallery
Freebies
Music Vids
