Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:18 am)
I hate to be the one to suggest something so possibly stupid, but I'll say it because its happened to me. Are the textures gone when you render, if not, check your document style and see if its set to "smooth shaded." It should be on "texture shaded."
Like I say, its the poser equivilant of forgetting to turn on the iron, but the simplest answer is quite often the right one.
Are you on MacOS? I seem to be suddenly running into strange issues with images after updating to the latest QT - BUM maps (extension changed to .bmp) show flat green. PNGs show weirdly. That said, though, Poser uses its own set of libraries (ImageIOPlugins) - so it would need to be even lower than QT (filesystem or worse).
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
question:
did you moved your runtime or installed a new version since using the items?
if so, try using CRPro to correct the file references in the library files.
My Homepage - Free stuff and Galleries
I have the same the problem, the textures are there in the material room but the little yellow error triangle is above them. even after deleting the current figure or even restarting poser, i load the figure check material room and it is fine but as soon as i start to render i get the error messages. and D/S also has no problem with the figure or the textures
Hello everyone i have a really big problem. I cant apply any textures to any figure, and all the saved scenes characters iv saved, open up without textures. When i try to open a saved character with clothes and body textures. Poser 6 says, (Texture could not be loaded. Image map file could not be found, or there is not enough memory.) And when i apply a texture to an already opened character poser 6 says, (A requested texture map does not exist or can't be read.) It's almost as if poser 6 cant read the textures. Can i have deleted some file? Since this happend poser 6 opens up in like 20sec, which is not normal for me. I have so much stuff installed it usually takes about 5 min to open. Can someone pls tell me what to do.
