Sat, Feb 1, 5:06 AM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: Photoshop newbie Q
Nosiferret ( ) posted Thu, 28 September 2006 at 8:08 PM ยท edited Sat, 01 February 2025 at 4:58 AM
HI there. I tried doing a search for this but the Search apparently works on all the forums, so I got a lot of junk for my efforts so I decided to post directly with my newbie question.
I am trying to make a solid line in Photoshop. And for the life of me I can't figure it out. You know where you can drag like a marquee over to copy something, isn't there a way that will make that line solid? I've discovered the line tool, like it will make a straight line from point A to B but it can be a little difficult to make a box out of it and make it look perfectly square.
ย
bushi ( ) posted Thu, 28 September 2006 at 9:02 PM
To make a square like that use the rectangular marquee tool to form the square the use Edit > Stroke to do the lines. You can also stroke any selection marquee the same way. Good Luck!
Nosiferret ( ) posted Thu, 28 September 2006 at 9:45 PM
Fantastic! Thanks bunches!
thundering1 ( ) posted Fri, 29 September 2006 at 9:26 PM
Another method, so you can edit in case you made the box the wrong size/length/wideth/tall, etc.
You create a new layer, make your box, fill it with a color, change the Fill of the layer to 0%, and apply the stroke with the Layer Styles command at the bottom of the Layers Palette - this way you can cut some off, add some more, etc., and the "line" will follow whatever you do to it - you don't have to do it over and over again if you want to change it later.
Good luck, hope that helps-
-Lew ;-)
bushi ( ) posted Fri, 29 September 2006 at 11:26 PM ยท edited Fri, 29 September 2006 at 11:27 PM
Soooo, dueling techniques huh? =) Here's a method to convert a selection to a path so you can use any brush you want. You could also just create a path with the path tools and stroke it this way without doing the convert selection to path step.
thundering1 ( ) posted Sat, 30 September 2006 at 9:09 AM
Bushi - that is slick! I've gotta try that - thanks for the tut!
-Lew ;-)
Nosiferret ( ) posted Mon, 02 October 2006 at 11:33 PM
Wow guys that's great! Thanks for replying :)
Keep dueling :)
Nosiferret ( ) posted Mon, 02 October 2006 at 11:42 PM
Now, I have seen a tutorial where you take a color, add noise to it and then do another technique to it that makes it "spray" out. You can use that tech for making iris textures, but I'm beating my head against the table right now as I can't find the tut and I've gone over my Photoshop and can't find any filter that will do that....it's driving me crazy :)
Nosiferret ( ) posted Mon, 02 October 2006 at 11:59 PM
I think i solved it...radical blur pumped up...I think :)
bushi ( ) posted Tue, 03 October 2006 at 12:17 AM
Yes, that sounds right. I've seen a couple of tutorials that use noise with radial blur as the basis for making iris textures.
