it's due to the transparencies in the feathers...if they were actually modeled then they would be proper. not that this helps you but it is what it is
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Has anything been done with the sketch room since Poser 1?
It seems to be the most primative of the Poser tools, although you can get nice effects with it from time to time.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
Ta
But why i want a scetch room that works so i can do large scenes and to get pictures like you used get in adventure book's, i posted 2 pics to my gallery using a plugin with photoshop not used on jasc yet.
Its a pity they dont work on a download to sort scetch room out as it be nice do big scenes just like in old book's.
It does work if you render your picture first, and then do the sketch render on the picture. That is what I did, the picture above is a sketch render straight from Poser6. It's like using Poser to add a filter effect, instead going to PhotoShop and doing it there.
Don Albert has some sketch presets for sale at DAZ that may give the kind of effect you are after, judging by your pictures.
http://www.daz3d.com/shop.php?op=itemdetails&item=2424
Ta for info on preset's for sale info
but in january i had already done a render with a picture i put on an ic3 background, but that does not do what i want, as the scetch room they never even botherd to fix.
If they cant program a PC then they should get another job as the sketch room should work how you want it, so if they cant do it then give the program to european, chinese, or japanese programers to get a working scetch room.
Done right the scetch room should work right as it should be not upto us the customers to find ways around problem's, but will buy some preset to see how they work.
But at least your enjoying ho you do your scetches.
Ta again
Bruce
I hate having to go through every bloody figure and prop to try find stuff that will render in sketch room have look at 2 pics 1 this message 1 in reply
