Mon, Feb 3, 2:53 PM CST
Subject: RTE encoder/decoder - help needed pls
barrowlass ( ) posted Wed, 04 October 2006 at 6:58 AM · edited Mon, 03 February 2025 at 12:08 PM
just a v. small, if dumb question.  I've not used RTE decoder before.  Only other I've used is Objaction Mover.  Can someone do a quick run thru on the processes in RTE, pls?
thanx
**Sheila
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
Gallery
Freebies
Music Vids
stahlratte ( ) posted Wed, 04 October 2006 at 7:44 AM · edited Wed, 04 October 2006 at 7:46 AM
Hi Sheila,
1, Open RTE-encoder.
  1. Tick "DECODE"
  2. Click "File to decode" and browse to the rte file you need decoded.
  3. Click "Key file", and a popup appears with the name of the file what was used to encode the rte file.
    Just browse to that file and click on it, and it will load into the middle slot.
  4. Click "Save as", and chose the folder you want the decoded file to be saved to. Hit save in the popup window.
If the key file was correct, a popup will show to confirm that the conversion was succesfull.
To protect DAZ copyrights, GIRL 3 had to be encoded TWICE, to make sure you have both AIKO as well as the GIRL.
So after you did the first decoding, you have to decode this new file AGAIN, but this time with a different key.
So AIKOGIRL 2.rte is converted into AIKOGIRL 1.rte
And AIKOGIRL 1.rte is then converted into  AIKOGIRL.obj
The keyfile for the first conversion is the blGirl. obj, the keyfile needed for the second conversion is blAiko 3.obj
Stahlratte
barrowlass ( ) posted Wed, 04 October 2006 at 8:30 AM
thanks Stahratte
very much appreciate the help - I'd not used RTE before so got into a muddle, lol.  Hope I can do something good with Girl 3 now!
Sheila
Gallery
Freebies
Music Vids
pitklad ( ) posted Wed, 04 October 2006 at 3:32 PM
this is included with NeaP4 but the steps are similar  for all encoded files :biggrin:
My FreeStuff
barrowlass ( ) posted Wed, 04 October 2006 at 4:26 PM
Thanx Pitklad, but managed to get sorted - see link below - am quite chuffed with result as I've never played around with morphs like this before 😄
Sheila
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2667187&page=6
Gallery
Freebies
Music Vids
