Sun, Feb 2, 11:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: "Faking" atmospheric effects for the Poser 4 Renderer?
Peacer ( ) posted Thu, 05 October 2006 at 5:27 PM · edited Sun, 02 February 2025 at 11:27 AM
To put it simply -- I cannot use Firefly.  I use Poser for animations, therefore I have to use the P4 Renderer to speed frames up (or it'd take years to finish an animation project).  I need to know if there are any tips or tutorials on how to simulate atmospheric effects without having to use Firefly?  I have the JepeZ Steams product, which works good for haze (as long as the camera doesn't move thru it).  However, in order to create the ambience I want, I need to simulate beam light -- like the light that might shine thru a window at night (not sure what else to call it).  In P4 I used to use simple props to achieve the effect, but I can't get this method to work in P6 for some reason.
Please help!  Thanks.
randym77 ( ) posted Thu, 05 October 2006 at 5:50 PM
Nerd3d.com has a tutorial on that.  I believe it uses his P4 fog prop.  Dunno if it would work in P6.
vince3 ( ) posted Thu, 05 October 2006 at 6:51 PM
the light type you mean is called "volumetric lighting" which i don't think you can do with the p4 renderer!
Peacer ( ) posted Thu, 05 October 2006 at 7:34 PM
Thanks, I'll check it out.  I'm assuming you're talking about the Fog Tool Delux III which should work (don't see why it wouldn't).  I was looking at a few screenshots, and it looks like it might do the trick.  If not, it's only $12.95, and I'm sure I can find many other uses for it!
Volumetric Lighting... wow, do I feel like a total moron.  I've always known that, but for some reason I had a major brain seizure and couldn't come up with a term.  Must be my 3D Modeling class...
Anyway, I know it can't be done with the P4 renderer, which is why I want to "fake" the effect -- as in using props to create fairly close results without resorting to the Firefly renderer.
If anyone else has any pointers, please let me know.
Elfwine ( ) posted Thu, 05 October 2006 at 8:05 PM
i have a pointer, i use P4 exclusively. Go to the "other" rosity site (the adult one) and do a search on my name. The title of the piece is "Before The Breech". There I simulated light rays piercing the water and i explained how i did it too! : ) hope that helps!
 Don't sweat the petty things, and don't pet the sweaty things!  ; )
