Sun, Feb 16, 5:30 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Carrara unstable - any suggestions?
lferrand ( ) posted Sun, 08 October 2006 at 9:24 AM · edited Fri, 07 February 2025 at 10:21 PM
I've been having a lot of trouble with Carrara going non-responsive on me lately. I'm working on a still image with 2 poser figures and about a dozen spline and vertex objects, and it crashes sooner or later in just about every session and I lose some work. I have an AMD Sempron 2GHz, 960 Mb RAM running Windows XP. Any suggestions from you techies on this problem?
Thanks,
Larry
falconperigot ( ) posted Sun, 08 October 2006 at 9:44 AM · edited Sun, 08 October 2006 at 9:47 AM
Resetting the Preferences will often sort out a problem like this.
In C5 Pro, just go to File>Reset Preferences.
GKDantas ( ) posted Sun, 08 October 2006 at 10:12 AM
Try to remove unused shaders and objects.
Follow me at euQfiz Digital
rendererer ( ) posted Sun, 08 October 2006 at 4:32 PM
My suggestion is to ask Daz to troubleshoot it for you. You've paid them, not the other way around.
dlk30341 ( ) posted Sun, 08 October 2006 at 5:07 PM
Also 960mb of ram is not much at all I'm afarid.  You should considering upgrading if at all possible.
Until then - check out the textures you are using on your Daz characters.  A lot of them come in around 3000x3000 to 4000x4000.  This eats up memory very fast.  If you have a paint program you want to consider reducing the texture sizes :) Maybe around 1000x1000 or even smaller if they are not being used for close ups.
bwtr ( ) posted Sun, 08 October 2006 at 7:39 PM
You do not mention your graphics card.  Has it been regularly updated?
Basically have you a system that is updated and meets the minimum specs required for Carrara?(The minimum specs is NOT the best specs for working with Carrara though!)
bwtr
keenart ( ) posted Thu, 19 October 2006 at 11:41 PM
A Sempron is basically an AMD Celeron, and that is probably your main problem.
jankeen.com
