@ UVDan: yes.. Poser has as part of their updates a ExportObject for Rhino exe for Poser 6.. go look in the update location... I just can't make it run.... or load into Poser...
It's a python-plugin which actually exports the poserscene as a wavefront-obj-file but converts it to the rhino-coördinate-system,it also copy all the textures as Jpg-files so you can render it in flamingo or any other rhino-renderer. It doesn't exports as a rhino- .3dm file and the geometry is still in mesh-surface format instead of nurbs-surfaces.
I'm sorry but I don't why the installer doesn't find the right path, I didn't have any problems, but my poser 6 is installed in the default directory.
Thanks Bopperthijs... I'm now clear as to what it does but my problem is still how to install it...
As I said it keeps tell me it can not find Poser6... even after I point it in the right folder....
Sorry it has taken me so long to get back to you. I have had a water heater tank out and had a closet full of mold and mildew to clean up and a new water heater to install. I can HIGHLY recommend Damp Rid's mold and mildew remover. One day the closet was smelling like mold and mildew and the next it was smelling like a hospital. WOW!! It took some paint off the walls, but I can live with that.
I will mosey on over to E Frontier, or Content Paradise and see if I cannot find the plug in and find out how to work it.
Free men do not ask permission to bear
arms!!
I took me a long while to get the download on dialup. Then I got the same error Tom did so I spent another long while getting the SR3 updater, then the plugin finally installed. Tom I can only suggest restarting your machine after updating and see if that helps. It worked for me.
arms!!
I already install the SR3 and re-booted and it still does not want to install.. I guess I'll have to go to e-Fronteer for advice...... There is something that the SR3 is not installing on my rig that the install needs to find........
Does anyone know why the Poser 6 ExportObject for Rhino exe dowload file tells me it can not find Poser 6 even after I point the installer to the right folder..... Is there something I don't know....
Tom
