Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
This is a great idea . Is there any restriction as to how many images you can submit? Could I submit an image that's been placed here at Rendrosity or elsewhere, or do they have to be previously unseen works?
You can submit as many images each month as you wish and there are no restrictions on it having been submitted elsewhere.
At the moment, I have a small limit on how much total space users have for uploading, 1024 KB, but I'll probably increase that some as we go. However, I only have 500 MB of webspace so I may have to put out more cash to increase that depending on how popular the gallery is. Guess I should start saving my pennies or skip a couple of meals. :P
There's a link at the top of the gallery page to the submission rules. They should cover any concerns/questions you have.
Thanks! I think I'll be posting something soon.... I hope this really takes off.
I'm having some problems uploading an image, Jelisa. When I get to the 3rd page (after the upload successful message) I'm getting a 404 error so the upload isn't completed.
FYI - I'm using IE7 and uploading from my computer.
Hugz from Phoenix, USA
Victoria
Belle, I got the same error when I forgot to select a gallery and used the back button to select one.
If I uploaded the image and clicked on continue after getting the success message, and selected a gallery and filled in the info, then clicked on Continue .. it worked.
Would you please try again and make sure you're selecting a gallery and not using the back button?
Well, Jelisa, I select the December 2006 gallery, even went into the gallery and then clicked on the Upload File link. It asked me for my file, I selected it from my O drive and clicked Continue. I got the 1 upload successful message and clicked on the Continue Button and got the 404 - can't display the webpage. Tried this four or five times but no joy. Didn't use the back button to reselect the Concept Gallery page, it's in my favorites folder.
Victoria
Javascript is enabled and I haven't seen a popup message. I've got my firewall set to access the site with no interruptions ... don' have a clue unless it's IE7. I might try with Firefox and see if I have the same results but I'm rendering right now and it's pretty much pegged my cpu (big scene, lots of elements).
Victoria
Okay jelisa, this is what I got today - all the upload fields were filled out.
Critical error
Script called without the required parameter(s).
File: /home/virtual/site135/fst/var/www/html/bryce/db_input.php - Line: 58
Array
[ID] => 4355e7d7fc19e71e6aa90aef1e3dc5e3
[am] => 1
[lang] => english
[liv] => Array
[0] => 11
[1] => 7
[2] => 8
[3] => 6
[4] => 2
USER DATA:
Array
[user_id] => 15
[user_name] => Victoria Lee
[groups] => Array
[0] => 2
[disk_max] => 1024
[disk_min] => 1024
[can_rate_pictures] => 0
[can_send_ecards] => 0
[ufc_max] => 0
[ufc_min] => 0
[custom_user_upload] => 0
[num_file_upload] => 1
[num_URI_upload] => 0
[can_post_comments] => 0
[can_upload_pictures] => 1
[can_create_albums] => 0
[has_admin_access] => 0
[pub_upl_need_approval] => 0
[priv_upl_need_approval] => 0
[group_name] => Registered
[upload_form_config] => 0
[group_quota] => 1024
[can_see_all_albums] => 0
[group_id] => 2
Queries:
Array
[0] => SELECT extension, mime, content, player FROM bryce_filetypes; (0s)
[1] => select * from bryce_plugins order by priority asc; (0s)
[2] => delete from catbirdstudios_net_-_bryce
.bryce_sessions where time<1162238064 and remember=0; (0s)
[3] => delete from catbirdstudios_net_-_bryce
.bryce_sessions where time<1161032064; (0s)
[4] => select user_id from catbirdstudios_net_-_bryce
.bryce_sessions where session_id=md5("952e140a6266ede45fda7df9f8524a49cb0a44961c29e67e16940a4dded9f081"); (0s)
[5] => select user_id as id, user_password as password from catbirdstudios_net_-_bryce
.bryce_users where user_id=15 (0s)
[6] => SELECT u.user_id AS id, u.user_name AS username, u.user_password AS password, u.user_group+100 AS group_id FROM catbirdstudios_net_-_bryce
.bryce_users AS u INNER JOIN catbirdstudios_net_-_bryce
.bryce_usergroups AS g ON u.user_group=g.group_id WHERE u.user_id='15' (0s)
[7] => SELECT user_group_list FROM catbirdstudios_net_-_bryce
.bryce_users AS u WHERE user_id='15' and user_group_list <> ''; (0s)
[8] => SELECT MAX(group_quota) as disk_max, MIN(group_quota) as disk_min, MAX(can_rate_pictures) as can_rate_pictures, MAX(can_send_ecards) as can_send_ecards, MAX(upload_form_config) as ufc_max, MIN(upload_form_config) as ufc_min, MAX(custom_user_upload) as custom_user_upload, MAX(num_file_upload) as num_file_upload, MAX(num_URI_upload) as num_URI_upload, MAX(can_post_comments) as can_post_comments, MAX(can_upload_pictures) as can_upload_pictures, MAX(can_create_albums) as can_create_albums, MAX(has_admin_access) as has_admin_access, MIN(pub_upl_need_approval) as pub_upl_need_approval, MIN( priv_upl_need_approval) as priv_upl_need_approval FROM bryce_usergroups WHERE group_id in (2) (0s)
[9] => SELECT group_name FROM bryce_usergroups WHERE group_id= 2 (0s)
[10] => update catbirdstudios_net_-_bryce
.bryce_sessions set time='1162241664' where session_id=md5('952e140a6266ede45fda7df9f8524a49cb0a44961c29e67e16940a4dded9f081'); (0s)
[11] => SELECT user_favpics FROM bryce_favpics WHERE user_id = 15 (0s)
[12] => DELETE FROM bryce_banned WHERE expiry < '2006-10-30 14:54:24' (0s)
[13] => SELECT * FROM bryce_banned WHERE (ip_addr='68.230.57.47' OR ip_addr='68.230.57.47' OR user_id=15) AND brute_force=0 (0s)
[14] => SELECT aid FROM bryce_albums WHERE visibility != '0' AND visibility !='10015' AND visibility NOT IN (2) (0s)
GET :
Array
POST :
Array
Page generated in 0.093 seconds - 15 queries in 0 seconds - Album set : ; Meta set: ;
Victoria
Quote - Try resizing to 1024 maximum pixels wide. That's the max width allowed.
I'll add the limits to the gallery description.
With the graphics library in php ur programmer should be able to write an automatic resampling function that checks the size of the submitted jpg and shrinks it if neccesary. It's very easy to build, only a few lines of code and it saves u the trouble of having people askin why their files arent working well. The chance that people will try and upload an image larger then 1024x768 is pretty high.
As an added benefit such a function could also be used for dynamic generation of thumbnails and other goodies like that which looks professional to ur users also.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
// function to create thumbnails
function createThumbnail($imageDirectory, $imageName, $thumbDirectory, $thumbSize)
$srcImg = imagecreatefromjpeg("$imageDirectory/$imageName");
$origWidth = imagesx($srcImg);
$origHeight = imagesy($srcImg);
if ($origWidth >= $origHeight)
$ratio = $origWidth / $thumbSize;
$thumbWidth = $thumbSize;
$thumbHeight = $origHeight / $ratio;
elseif ($origWidth < $origHeight)
$ratio = $origHeight / $thumbSize;
$thumbHeight = $thumbSize;
$thumbWidth = $origWidth / $ratio;
$thumbImg = imagecreatetruecolor($thumbWidth, $thumbHeight);
imagefill($thumbImg, 0, 0, imagecolorallocate($thumbImg, 255, 255, 255));
imagecopyresampled($thumbImg, $srcImg, 0, 0, 0, 0, $thumbWidth, $thumbHeight, $origWidth, $origHeight);
imagejpeg($thumbImg, "".$thumbDirectory."/thumb_".$imageName."", 90);
(_/)
Attached Link: Bryce Concepts Gallery
Since we lost the Bryce Forum Select Galleries some time back, I've been trying to come up with a similar concept without duplicating the select gallery. I've been visiting different submission galleries and think I've come up with a working solution.Please check out the new Bryce Concepts Gallery where you can submit your images and have them selected by a group of anonymous judges for entry into the permanent monthly galleries. Judges will be revealed when the permanent gallery is set up each month.
If you would like to be a judge, send me an e-mail at darlisa @ catbirdstudios.net and I'll put you on the potential judges list I'll keep here at home.
Since this is just starting up, some rules may change as we find things that do or don't work for us.
-darlisa
