Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
It can?! I didn't know that. Any format that I could use in Poser, and if lightwave works, that will be just fine!
Off to try! Thanks :)
say." - Ghandi
Attached Link: http://lwg3d.org/v3/meshes.php?cat=27
I was able to import the lightwave object, but it arrived in my preview window untextured as expected. I went to the material room to apply the texture that comes with the lightwave object, and once rendered the texture looks like sofa fabric and nothing like the images of the object that I downloaded.
I'm trying to render the two Pluto files found at the above link.
Here is the render of what I get.
say." - Ghandi
say." - Ghandi
say." - Ghandi
say." - Ghandi
say." - Ghandi
I have version 6, and it shows that I can import lightwave, but the textures don't seem to work.
say." - Ghandi
Attached Link: http://mysite.verizon.net/sfg0000/
get thee to Poseray.. use that to convert thy LWO to thy holy OBJ.... it worketh. verily, it is excellent unto this task...Thanks for the link to PoserRay! That worked great! I converted it to .obj and imported it to Poser and was able to render an object with the proper texture.
Wraith, the problem is that I don't have lightwave. I only have Poser 6 and I wanted to use a lightwave object, but for some reason while I could import the object itself, the texture was wonky.
This PoserRay is really easy to use, even I managed to figure it out without any problem!!!! That is definitely a program created with software dummies like me in mind!!! :)
say." - Ghandi
I use poser and lightwave quite a bit - more LW than P...
A much under rated tool for converting objects is Accutrans 3d. It's fully functional shareware, cheap to register, and and does a superb job of translating between formats. It can do quite a bit of cleaning up as it goes too, and the author is VERY helpful.
For more heavy duty stuff with Poser in Lightwave, Greenbriar Tools is pretty powerful, (and also available for other 3d packages). I use it mainly for getting poser content into lightwave. It can get a bit more pricey with all the modules, but it does a good job. It's the best one I know for getting textures intact between programs.
http://www.greenbriarstudio.com/3D/
It's got some rather impressive options for getting models the other way too.
For using poser stuff in lightwave on the cheap I made a tutorial:
http://www.starbase1.co.uk/tutposer1.html
Part 2 still not written which will cover animating.
Nick
I like the PoserRay so far, it seems to do a good job. For I was looking at some cars the most of them is lightwave and 3ds with this program it looks like it will do the job right. Thanks for sharing you all...
David J Harmon
davidjharmon.com
Any chance the UV mapping is lost in the import? I know that when you export a UV-mapped model from LW as an OBJ, the mapping is lost unless the surfaces have textures applied when the model is exported.
I just use LW to export the OBJ, rather than trying to import a LW file into Poser; haven't had any problems since I learned that little tidbit about applying textures first.
Is there a free program that can convert lightwave files to a format that I can use in Poser?
