Wed, Jan 15, 12:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Subject: Need help rendering a large image in Poser 6/ Firefly
JHoagland ( ) posted Sun, 29 October 2006 at 11:15 AM · edited Tue, 14 January 2025 at 5:52 PM
My objective is to render a a 24x36 inch image at 200 dpi. This results in a 4800x7200 pixel image, which is a high enough resolution for a large-scale printer.
I am using Poser 6 with the latest service packs on Windows XP. I'm rendering the image on my laptop and there are no other programs running. I only opened the one scene file, so there are no extra "things" floating around in Poser's memory.
First, I can't use the Poser 4 renderer: Poser gives me an error that this renderer doesn't support rendered images larger than 4096x4096.
When I use the Firefly renderer, the rendering runs for about an hour, then stops at the "Rendering" step with this message:
"There was error rendering the image. To reduce the memory used by Poser, try the following: uncheck texture filtering or reduce the bucket size."
(Sorry, I forgot to take a screen shot of the exact wording.)
As you can see from the screen shot of my render settings, I'm already rendering with "texture filtering" off.. as well as "raytracing" off, a bucket size of 64, and a Max texture size of 2000 (instead of the recommended 3564).
Does anyone have any good ideas? Or should I lower the dpi and the size of the image? A 24x36 inch image at 100 dpi will be 2400x3600 pixels, which is half the size. But will the image look pixelated when printed?
Thanks
--John
VanishingPoint... Advanced 3D Modeling Solutions
JHoagland ( ) posted Sun, 29 October 2006 at 11:27 AM
Never mind. :)
I reduced the bucket size to 32 and it's rendering now.
--John
markschum ( ) posted Sun, 29 October 2006 at 11:28 AM
I would try a bucket size of 32 or even 16 and render directly to file.
thefixer ( ) posted Sun, 29 October 2006 at 11:47 AM
That's what I was gonna say, I always use bucket size 32 or lower!!
Injustice will be avenged.
Cofiwch Dryweryn.
tainted_heart ( ) posted Sun, 29 October 2006 at 12:01 PM
Quote - I would try a bucket size of 32 or even 16 and render directly to file.
I don't think it's possible to render to a file with Poser. If you've found a way to do this I'd appreciate it if you'd share it.
It's all fun and games...
Until the flying monkeys attack!!!
Miss Nancy ( ) posted Sun, 29 October 2006 at 1:03 PM
well, anyway, it renders directly to a series of addresses in RAM (or maybe VM) whilst the render appears in a new window. then ya gotta save it. that's as opposed to rendering animations, which seem to save to a file, then the rendered animation appears in a new window (at least in mac OS). so in the unlikely event that poser crashes when trying to display the rendered animation, ya still got a file on yer disk.
vince3 ( ) posted Sun, 29 October 2006 at 4:44 PM
when i need to render big i always use these settings,always works for me:
vince3 ( ) posted Sun, 29 October 2006 at 4:45 PM
and these:
vince3 ( ) posted Sun, 29 October 2006 at 4:50 PM · edited Sun, 29 October 2006 at 4:53 PM
but if you have trouble i reakon you could render smaller but increase your pix/in (mine is maxed) then take the render to photoshop, open a new blank document, the size and dpi you want it to be e.g 3000x3000 at 300dpi (for print),  then stretch the render to fit, with the increased resolution settings you should have little or no pixelation.
Miss Nancy ( ) posted Sun, 29 October 2006 at 4:56 PM
there's probably no reason to render at anything other than screen resolution since poser will display it at screen resolution. photoshop can change the pixel resolution to print resolution (300dpi for ordinary inkjet printers).
